  S10 Brake Booster Install
S10 Brake Booster Install by Vedder210
Started on: 03-11-2025 02:14 PM
Replies: 4 (153 views)
Last post by: Vedder210 on 03-12-2025 04:09 AM
Vedder210
Report this Post03-11-2025 02:14 PM Click Here to See the Profile for Vedder210Send a Private Message to Vedder210Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm in the process of installing an S10 Booster with Rodney's adapter. Well I ordered the wrong size which is not a problem because I had it turned down 3/8" on the lathe at work. When I go to attach it to the brake pedal it beyond the post by about 1/4" I would say and yes I pulled the pedal out as far as it would go. My question is do you need to remove the nut that came threaded on the S10 arm? Thanks
Total ratings: 328
Report this Post03-11-2025 05:35 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe that nut locks the position of the brake booster adapter in place at the proper length,
Vedder210
Report this Post03-11-2025 05:40 PM Click Here to See the Profile for Vedder210Send a Private Message to Vedder210Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just did a test fit without the nut, and screwing the adapter all the way down, it lined right up to the pin on the pedal with the pedal pulled all the way out. Going to loctite it on and keep on eye on it for movement. Thanks for the input.
Total ratings: 328
Report this Post03-11-2025 09:00 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Surprised that the adapter had to be fit to the rod that way but with Loctite on the threads its probably secure. Did you reuse the oldFiero Booster brackets on the new booster?
Vedder210
Report this Post03-12-2025 04:09 AM Click Here to See the Profile for Vedder210Send a Private Message to Vedder210Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yep, I reused the bracket from the original booster.
