  Oil in cylinder
Oil in cylinder by ViperRedFiero
Started on: 03-10-2025 07:09 PM
Replies: 6 (135 views)
Last post by: ViperRedFiero on 03-12-2025 07:31 PM
ViperRedFiero
Report this Post03-10-2025 07:09 PM Click Here to See the Profile for ViperRedFieroSend a Private Message to ViperRedFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi guys I need help with my 86 Fiero v6. It recently was having problems at idle and seemed like it was only running in a couple cylinders at low rpm’s. Today it shut off on me and I can’t get it started it’ll crank and fire in one cylinder all day but it won’t start even with starting fluid. It seems to have spark and the compression averages about 125 psi. The concerning thing is that there seems to be a lot of oil in the cylinders cuz every time I take the compression tool off it’s completely full of oil but the car only ever smoked a little bit at start up and it doesn’t spray oil when I’m cranking it over with the spark plug out so I’m pretty confused.
I know it’s probably the valve seals but I’m looking for some expert advice before I start tearing it apart.
Any help is appreciated.
Total ratings: 465
Report this Post03-10-2025 07:18 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by ViperRedFiero:
It seems to have spark...
Does it have SPARK... or spark ?
A healthy spark will easily snap across a 1/4" gap to ground.
The concerning thing is that there seems to be a lot of oil in the cylinders...
Were the spark plugs showing evidence of being oil-fouled?
[This message has been edited by Patrick (edited 03-10-2025).]
ViperRedFiero
Report this Post03-10-2025 07:25 PM Click Here to See the Profile for ViperRedFieroSend a Private Message to ViperRedFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah they are kinda black but they didn’t seem to be soaked in oil like the compression tool was when I took it out
ViperRedFiero
Report this Post03-11-2025 02:02 PM Click Here to See the Profile for ViperRedFieroSend a Private Message to ViperRedFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Right now I’m just trying to confirm that it’s the valve seals not the piston rings.
Is 125 psi ok for that engine?
Any help is appreciated thanks.
1985 Fiero GT
Report this Post03-11-2025 02:18 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Use a ir temperature gun on the exhaust manifold ports, and start to find exactly which cylinders are firing and which are not, then look at every cylinder spark plug for oil, if the ones that don't have combustion have oil, but the ones that are firing don't, then that's probably not a problem, just find out why it isn't combusting. On a rebuild last summer I left a fuel injector unplugged, and for whatever reason, whether just the build up of tiny amounts of oil from the rings or whatever (new valves etc) that cylinder had noticeable oil in it, spark plug was oily and fouled. Plugged in the injector, ran it a while and all was good and normal afterwards.
Check your injector fuses and do the temperature test, of you don't have an ir thermometer, run it for 30 seconds, then use an eyedropper with a little water on each port, low tech but should work.
Report this Post03-12-2025 05:53 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
125 PSI is a decent compression number for a cyl... but IF there is an oil problem, the good compression could be as a result of the oil. The oil tends to improve compression because it fills in the gap in the rings. Seems unlikely though that it would be dumping that much oil... I'm thinking it's more likely a problem like what Patrick and 85 GT is saying.
ViperRedFiero
Report this Post03-12-2025 07:31 PM Click Here to See the Profile for ViperRedFieroSend a Private Message to ViperRedFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have an ir temperature gun so I’ll try and check to see which cylinders are firing but I still can’t get it to start so it might be kind of difficult.
Starting fluid didn’t do anything so I don’t think it’s a fuel issue but I’ll check it out this weekend.
I appreciate the help. Thanks
