  Will an 88 engine wire harness fit an 87 engine?
Will an 88 engine wire harness fit an 87 engine? by the_snowman
Started on: 03-09-2025 06:05 PM
Replies: 20 (203 views)
Last post by: olejoedad on 03-12-2025 10:10 PM
the_snowman
Report this Post03-09-2025 06:05 PM Click Here to See the Profile for the_snowmanSend a Private Message to the_snowmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am still very new to the fiero as a car.
So i have swaped an 87 engine to a manual 5 speed 88.
What i am very curious to is if an 88 engine wire harness will work with an 87 engine?
Secondly, will the 88 computer work with an 87 engine?
Total ratings: 260
Report this Post03-09-2025 06:20 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
4cly or V6?
the_snowman
Report this Post03-09-2025 06:23 PM Click Here to See the Profile for the_snowmanSend a Private Message to the_snowmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
V6 2.8L
Total ratings: 207
Report this Post03-09-2025 07:12 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes.
They are the same.
Did you use the 87 flywheel on the 87 engine?
[This message has been edited by olejoedad (edited 03-09-2025).]
the_snowman
Report this Post03-09-2025 07:14 PM Click Here to See the Profile for the_snowmanSend a Private Message to the_snowmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you!!
Total ratings: 207
Report this Post03-09-2025 07:15 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
the_snowman
Report this Post03-09-2025 07:18 PM Click Here to See the Profile for the_snowmanSend a Private Message to the_snowmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
i did indeed.
Total ratings: 207
Report this Post03-09-2025 07:29 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's good, the two engines are balanced differently.
The cooling system hoses are routed differently as well, it's easy to convert.
the_snowman
Report this Post03-09-2025 07:33 PM Click Here to See the Profile for the_snowmanSend a Private Message to the_snowmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
i did not know that the coolent hoses where routed diffrently.
is there a video or instructions online on how to re rought them?
(i am keeping everything in my 88 GT exeptfor the engine. it is also a 5-speed manuel)
thank you for the heads-up!!
Total ratings: 328
Report this Post03-09-2025 08:46 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'd like to point out that while the 85-88 V6 wiring harnesses are essentially the same , the manual harness will not work on an automatic without turning on the feature flag in the chip that instructs the ECM program to lock up the torque converter when required. If the haness and ECM are swapped together then no chip reprogramming is required.
the_snowman
Report this Post03-09-2025 08:53 PM Click Here to See the Profile for the_snowmanSend a Private Message to the_snowmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great point!
I am keeping the computer and the harness from the manuel 88 so that sould be good if you are correct.
( I am assuming you are)
Total ratings: 207
Report this Post03-10-2025 06:45 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I may have spoken incorrectly about the cooling system routing.
The heater core water returns to the passenger side cooling pipe in both years.
The heater core feed may be different.
Examine the water pumps, the 87 may have a tube where the 88 has a plug in that location.
I will check my Factory Service manuals and get back to you.
Total ratings: 260
Report this Post03-10-2025 07:51 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
You should plan to swap the accessories (at least the alternator) as I think it is different.
88 Y-pipe has better heat shielding and should be swapped over (along with the rest of the exhaust).
In 88 they did away with the cooling blower for the alternator and ignition coil, and the 2 changes above were to facilitate that change.
I Lean
Report this Post03-10-2025 09:02 AM Click Here to See the Profile for I LeanSend a Private Message to I LeanEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 87 feeds the heater core from the thermostat housing.
Total ratings: 207
Report this Post03-10-2025 09:19 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
So does the 88.
To the original poster....
Both model years return the heater core flow to the passenger side undercar coolant tube.
There is NO DIFFERENCE in cooling system layout.
GodSend
Report this Post03-11-2025 11:56 AM Click Here to See the Profile for GodSendSend a Private Message to GodSendEdit/Delete MessageReply w/QuoteDirect Link to This Post
88 alternator plug will be slightly different. You can keep 87 alternator and splice in correct pigtail, or upgrade to better 88 only alternator.
Total ratings: 202
Report this Post03-11-2025 12:33 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
And if you want to buy one, Rodney Dickman sells an adaptor for $15 bucks here: https://rodneydickman.com/p....php?products_id=361
the_snowman
Report this Post03-11-2025 09:29 PM Click Here to See the Profile for the_snowmanSend a Private Message to the_snowmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
So if i kept the 87 alternator, then i would need to buy an adapter for the 88 wireing harness?
Total ratings: 207
Report this Post03-11-2025 09:37 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Or, you could
1. Wire in the plug from the 87 harness. (It's only 2 wires, just match the colors)
2. Use the 88 alternator ( it's a better alternator, and your best choice)
Total ratings: 154
Report this Post03-12-2025 08:27 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
The two differences in the 87 and 88 engine harnesses that come to mind are the alternator and oil pressure sending unit. Each can be changed out to match the harness.
Total ratings: 207
Report this Post03-12-2025 10:10 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the O/P transfers accessories from the 88 engine to the 87 engine, no wiring harness changes are needed.
