  Spring Reminder: Check the Health of Often Neglected Coolant & Brake / Clutch Fluids!
Spring Reminder: Check the Health of Often Neglected Coolant & Brake / Clutch Fluids! by Vintage-Nut
Started on: 03-08-2025 01:53 PM
Replies: 1 (68 views)
Last post by: Dennis LaGrua on 03-14-2025 04:12 AM
Vintage-Nut
Report this Post03-08-2025 01:53 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Springtime is a great time to check these fluids!
When to Change the Coolant?
Coolant is a blend of antifreeze and distilled water prevents corrosion, rust and scale buildup, plus helps transfer heat. It also keeps the liquid from freezing and prevents overheating.
But over time, all antifreeze breaks down. The pH balance of deteriorated coolant and the antifreeze depleted corrosion inhibitors become drastically more acidic over time which causes corrosion. Corrosion can ‘attack’ and damage the radiator, water pump, heater core as well as other cooling parts in the system.
Inorganic Acid Technology (IAT) needs frequent changes, typical every 2 years.
Organic Acid Technology (OAT) lasts much longer, generally 5-8 years as the maximum of 10 years.
Use pH strips to keep an eye on the system; deteriorated coolant must be entire flushed
If you’re in doubt about the ‘health’ of the coolant, completely flush the system.
When to Change the Brake Fluid?
DOT 3 and DOT 4 brake fluids are hygroscopic, which means it attracts and absorbs water molecules from the surrounding atmosphere.
Once the corrosion inhibitor additives in the brake fluid are spent; moisture contamination leads to corrosion or ‘rusting’ of metal components. These compromised parts can begin to slough off some of their materials; especially the Fiero Rear Brake Calipers!
The manual says to change the brake / clutch fluid every 2 years.
DOT 3 and DOT 4 brake fluids are suitable for the Fiero brake systems: not DOT 5.
DOT 4 brake fluid offers better heat resistance than DOT 3, however DOT 4 absorbs moisture 20% faster than DOT 3
Since I drive in normal street conditions and DOT 3 brake fluid absorbs less water than DOT 4, I use DOT 3 in my Fiero.
Use pH strips to keep an eye on the fluid; deteriorated fluid must be entire flush and bleed out; especially the rear piston actuator {aka the parking brake mechanism}
Phoenix Systems 8006-B Double-Ended Brake Fluid + Coolant Test Strips (15 foil wrapped test strips)
[This message has been edited by Vintage-Nut (edited 03-08-2025).]
Total ratings: 328
Report this Post03-14-2025 04:12 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good tips and post Like to add that coolant and brake fluid in a collector car driven say under 1000 miles per year should in theory last longer. As to how long I can't say. as a plus you can buy an inexpensive brake fluid tester that will detect any water in the brake fluid. I got mine for $3 on eBay.
[This message has been edited by Dennis LaGrua (edited 03-14-2025).]
