  Cleaning the weird gunk out of the electrical connectors.
Cleaning the weird gunk out of the electrical connectors. by Filben
Started on: 02-27-2025 05:20 PM
Replies: 8 (180 views)
Last post by: Dennis LaGrua on 03-06-2025 09:51 PM
Filben
Report this Post02-27-2025 05:20 PM Click Here to See the Profile for FilbenSend a Private Message to FilbenEdit/Delete MessageReply w/QuoteDirect Link to This Post
So, what is the best way to clean that nasty crud out of the electrical connectors? I sprayed a bunch of electrical contact cleaner in it and now its just leaking the nastiest brown goo. I used a small pick and cleaned as much chunks out as I could but I would really like to have it stop leaking goo.
Report this Post02-27-2025 05:59 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
DO NOT CLEAN IT OUT!
That's the stuff GM put in the connector to waterproof it.
It works better than anything else I've found.
BIG MISTAKE!
Now you'll have to find something else to waterproof the connection, and nothing compares to the stuff GM used.
[This message has been edited by olejoedad (edited 02-27-2025).]
Filben
Report this Post02-27-2025 07:11 PM Click Here to See the Profile for FilbenSend a Private Message to FilbenEdit/Delete MessageReply w/QuoteDirect Link to This Post
BIG MISTAKE!
I know its the dielectric grease they used, but its almost a solid now, its nasty and I can put new grease in. Im not worried about keeping it.
IMSA GT
Total ratings: 250
Report this Post02-27-2025 07:17 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
BIG MISTAKE!
Do you happen to know what the original material was? Seems like no one is really sure.
RWDPLZ
Total ratings: 305
Report this Post02-27-2025 07:26 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'd swear it's just butyl
LS4FieroGuy
Report this Post02-27-2025 08:10 PM Click Here to See the Profile for LS4FieroGuySend a Private Message to LS4FieroGuyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've found that a small pick and CRC Electrical parts cleaner works extremely well. Then just apply a liberal amount of dielectric grease and you're good to go.
Report this Post02-27-2025 08:45 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've been told that it's a form of cosmoline.
I've seen it dry out on the surface, but below the surface it's still very pliable and sticky.
When I repin the C500 for swaps, I'm able to easily repack the fitting with the old material to prevent water intrusion.
1985 Fiero GT
Report this Post02-27-2025 10:23 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is thick, yes, but it is not ordinary dielectric grease, it's special gm stuff, other commonly available greases run out, or dry up, or whatever, but the gm stuff is nasty but works the best, if you can physically plug the connector together and apart, it's fine, leave it, maybe add a small amount of lighter grease in as well to fill any voids from the old stuff coming out or drying up.
Report this Post03-06-2025 09:51 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The problem with the connector compound is that if you are rewiring for a swap, it makes it very difficult to remove the pins. Its probably a good thing to have on connectors but not when you are re-pinning/re-wiring the connector maybe not. When I had to rewire, change or replace pins I just pushed the stuff out of the way with a small screwdriver.
