Be advised the 3800NA and 3800SC series II engines are not the same. Different compression pistons, heads, and the later Series III engines are different still.. Connecting rods on the series III were switched to sintered metal, the heads were slightly ported and the supercharger was modified to run cooler.. I would recommend having an engine shop rebuild what you already have. Shops that build race engines do that type of work. If there is a race track in your area you can ask there to find those shops.
