  interior door panel metal brackets
interior door panel metal brackets by geltzer
Started on: 02-05-2025 09:26 AM
Replies: 9 (243 views)
Last post by: richard in nc on 08-20-2025 08:56 AM
geltzer
Report this Post02-05-2025 09:26 AM Click Here to See the Profile for geltzerSend a Private Message to geltzerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi
i have a small problem with my door cards / interior door panels.
the problem is that the small metal brackets that have been pressed into the cardboard inner plate, (2 per panel) has been ripped out when a former ower took the panels of.
so in order to get the panel back on the car, i need to reproduce these in some way.
is there anyone who can guide me how to do this and glue them back in, in a way that will hold up? or maybe even somewhere i can can new ones?
Mike in Sydney
Report this Post02-05-2025 03:58 PM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pictures?
Post pictures of the panels where the plates are supposed to be.
cliffw
Total ratings: 292
Report this Post02-05-2025 04:06 PM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Mike in Sydney:
Pictures?
Also the plates. WE might be able to redneck engineer something which will work.
Also, welcome to the Forum.
geltzer
Report this Post03-06-2025 09:13 AM Click Here to See the Profile for geltzerSend a Private Message to geltzerEdit/Delete MessageReply w/QuoteDirect Link to This Post
sorry about the late answer, i ended up bending some new ones out of sheet metal and gluing them on with construction adheasive
Vintage-Nut
Report this Post03-06-2025 11:23 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
But you did close the loop which is very rare...Well Done!
It is sad that many PFF members will not report back on the overall findings or outcome of "whatever" the task may be.
Total ratings: 200
Report this Post03-06-2025 11:37 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry I missed this. I would have recommended doing something similar. You can buy replacements online, they're basically pressed in, but you can use Gorilla Glue (which works really well, but takes as long as construction adhesive to set), and that'll keep them in there pretty much forever.
richard in nc
Report this Post08-18-2025 01:43 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
i have the gorilla super glue gel.is that the one to use?
turns out its dried up.which one should i buy?
[This message has been edited by richard in nc (edited 08-18-2025).]
jelly2m8
Total ratings: 242
Report this Post08-18-2025 07:11 PM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
To the OP that's about the best we can do with them, find the strongest glue we can find and hope for the best
Report this Post08-20-2025 03:28 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
As for a strongest glue that I've ever used ; JB Weld (2 part epoxy) is my choice, holds well to almost any material but dries hard. If you want a strong glue that remains a bit flexible, E6000 is a good choice. For applications that require some flex like a door panel I would use E6000.
[This message has been edited by Dennis LaGrua (edited 08-20-2025).]
richard in nc
Report this Post08-20-2025 08:56 AM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
my main concern is the back of the panel appears to be cardboard.i can clearly see where it was attached before so i don't want to sand it and then put it back in the wrong place.
