  removing 4t40 from parts car.
removing 4t40 from parts car. by richard in nc
Started on: 02-02-2025 12:51 PM
Replies: 7 (181 views)
Last post by: Dennis LaGrua on 02-09-2025 11:15 AM
richard in nc
Report this Post02-02-2025 12:51 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
since you are supposed to use pontiac 6000 axles to swap it into a fiero 2.5 i was wondering if i can just cut the axles near the transmission instead of removing the whole axles?the donor is a 1989 reatta.the reason i want to do this is its easier and leaving the axles in the trans keeps out dirt.
Report this Post02-03-2025 12:57 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the junkyard doesn't object that might be a good approach but cutting through a hardened steel axle may not be all that easy. Then you would probably have to swing whats left of those axles out of the way to drop the transmission. The exhaust crossover may also need to be removed.
Your idea is to put an automatic transmission designed for application on a 3800 engine on the Fiero Duke engine. I would check gear ratios before moving forward.
Total ratings: 463
Report this Post02-03-2025 01:10 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Survey says "2.97".
https://forums.aaca.org/top...9-trans-final-ratio/
richard in nc
Report this Post02-03-2025 02:30 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Raydar:
Survey says "2.97".
i have the reatta.its totalled.i bought the fiero with the intent of swapping in the 3800 and trans into the fiero.ive been told thats not a good idea.im preparing to have it towed but id like to keep the trans in case the three speed dies or i start driving the fiero on trips.currently i have a chevy bolt for trips.
Report this Post02-03-2025 07:32 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Why would it not be a good idea?
Even the early 3800's were decent engines.
richard in nc
Report this Post02-05-2025 12:51 AM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
i was told it was a bad idea because the engine was an inch taller,only 160 hp,uses a different wiring harness,uses different mounts than a series two.the idea was id want to 'upgrade'to a series two later and id need different stuff to do that.
Mike in Sydney
Report this Post02-05-2025 04:05 PM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lots of 3800 swaps around. Check the archives. I’m sure I’ve seen lists of what’s needed for these.
Report this Post02-09-2025 11:15 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The series 1 3800 engine would probably provide reliability but it is a lot of work for 160HP. You could equal that with the 3.4L P/R engine that would bolt in easier with the 2.8L harness cradle and ECM. Minor harness changes would be required for Fieros 85-88. The 84 Duke has very different wiring and would be more difficult.,
