  Fiero hoist points
Fiero hoist points by saving_rossi
Started on: 01-29-2025 01:02 AM
Replies: 9 (201 views)
Last post by: Raydar on 02-08-2025 12:57 PM
saving_rossi
Report this Post01-29-2025 01:02 AM Click Here to See the Profile for saving_rossiSend a Private Message to saving_rossiEdit/Delete MessageReply w/QuoteDirect Link to This Post
The crade is dropped, fully disconnected from fiero. I currently have a chain wrapped around the piece of metal connecting the rear frame rails, and I’m considering using tow straps instead. I don’t trust the piece of metal much.
Should I trust this arrangement? If not, how should I arrange tow straps?
Total ratings: 465
Report this Post01-29-2025 02:03 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
This isn't my photo/Fiero, but this is how I've supported my Fiero(s) a couple of times when dropping the cradle/replacing the clutch.
saving_rossi
Report this Post01-29-2025 06:12 AM Click Here to See the Profile for saving_rossiSend a Private Message to saving_rossiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Guess I’ll start pulling the trunk skin then. Did the hoist legs interfere with the cradle/dolly at all?
Report this Post01-29-2025 06:54 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I use the same lift points in the strut tower crossbar to raise and lower my fiero. You can extend the legs of the cherry picker and set the cradle on them. Remove the bolts, then raise the body up, install jack stands, and then roll the cherry picker and drivetrain out from under the Fiero. No need for a separate cradle dolly with this process.
saving_rossi
Report this Post01-29-2025 07:33 AM Click Here to See the Profile for saving_rossiSend a Private Message to saving_rossiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Total ratings: 200
Report this Post01-29-2025 09:18 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi, I highly recommend doing it the way my daughter removed her subframe. She removed the rear bumper, and wrapped heavy-duty tow-straps around the rear steel bumper. It allows you to have the hoist much further back, and gives you significantly more clearance for the subframe... see this video:
I made a subframe dolly for her, which I wish I'd had before... but it's simple using 4x4s... you can see that in this video:
[This message has been edited by 82-T/A [At Work] (edited 01-29-2025).]
cvxjet
Report this Post01-29-2025 11:56 AM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used a high-strength cargo strap wrapped around/under the trunk to lift my Fiero....
saving_rossi
Report this Post01-29-2025 03:14 PM Click Here to See the Profile for saving_rossiSend a Private Message to saving_rossiEdit/Delete MessageReply w/QuoteDirect Link to This Post
I’ve actually been watching this video to help drop the cradle! What a small community. I saw the part with the tow straps and I wasn’t sure exactly how she arranged them, I could just wrap them round it however but it seemed like she did it a specific way.
Total ratings: 200
Report this Post01-29-2025 03:59 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
She did it just to "take up the slack" and limit the distance that was needed from the hoist to the bumper. But really, she could have just used one, wrapped it along the bottom and up through the sides (frame extensions where the bumper bolts to), and then hook it in there. But really... it all depends on what straps you get and how long they are. Ideal situation is to put the hoist hook as close to the bumper as possible so you have more room (less height) for the hoist as you raise the car up. But yeah, it worked well, and felt it was pretty safe, and the least damaging to any of the other parts of the car.
Total ratings: 463
Report this Post02-08-2025 12:57 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
It may not be practical in some cases, but I had someone build me an A-frame - aka "the swingset from hell".
I bought a hoist from Harbor Freight, and use a chain through the trunk beam, as others have done.
It can lift the rear of the car high enough that I had to put the front on ramps, to keep from crushing my front bumper cover.
The cradle was unbolted while the rear of the car was resting on a furniture dolly. Once the car was raised, there was enough room to roll the dolly and engine straight out the back.
Edit - The cherry picker will also work fine, but I was doing this a lot, at the time.
I reasoned that safety was paramount, and the A-frame was cheaper than the deductible for even one ER trip, if I had a car to fall.
BTW... DON'T use the trunk latch to lift. I've seen it done, and it's dumb.
[This message has been edited by Raydar (edited 02-08-2025).]
