  1988 GT A/C compressor dying - new replacement?
1988 GT A/C compressor dying - new replacement? by John W. Tilford
Started on: 01-28-2025 03:31 PM
Replies: 7 (151 views)
Last post by: Dennis LaGrua on 01-30-2025 09:35 PM
John W. Tilford
Report this Post01-28-2025 03:31 PM Click Here to See the Profile for John W. TilfordClick Here to visit John W. Tilford's HomePageSend a Private Message to John W. TilfordEdit/Delete MessageReply w/QuoteDirect Link to This Post
My 1988 GT has a 3.4 6 cyl same size block as stock 2.8. Shop says air compressor leaking.
Question: Didn't I see a few years ago in the Forum there is a more efficient, smaller, air conditioning compressor which would fit right in the same location? Shop thought their trying to get an identical replacement for the stock compressor would be expensive.
Please tell me I'm not imagining this and help me find where to locate the new & improved replacement?
As always, thank you. The Forum has seen me through several issues since I bought the GT in 2005.
John T
John W. Tilford
Report this Post01-28-2025 04:45 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
If its the original compressor then replacement is a good idea. I believe that compressor may be a Harrison model HR 6. They are available new.
Most later GM compressors have pulleys for serpentine belts. The Fiero w 2.8L uses an old style V belt and pulley so a direct fit with a later compressor would at the minimum require changing the clutch and pulley. Then what clutch and pulley for a V Belt would fit a more modern V22 compressor. IMO the best and easiest option is to replace what you have with the same type.
Vintage-Nut
Report this Post01-28-2025 04:53 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Also, read the Introduction on this thread:
AC Compressor Switches by RWDPLZ
https://www.fiero.nl/forum/Forum2/HTML/117640.html
RWDPLZ
Total ratings: 305
Report this Post01-29-2025 10:50 AM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
The stock replacement isn't expensive at all compared to what they cost 20 years ago. A shop might charge an arm and a leg to do it, though.
Stock replacement would be an HR6, Four Seasons makes a new one, part number 58255, they're typically a bit over $200
https://www.4s.com/en/ecata...8255&type=p&search=s
82-T/A [At Work] was looking into replacing the HR6 with a V5, which is a smaller variable displacement compressor. I don't believe he ever worked out the details, you could ask him. IMO it would be a better idea to replace the part than to try and re-invent the wheel.
https://www.fiero.nl/forum/Forum2/HTML/147512.html
John W. Tilford
Report this Post01-29-2025 11:49 AM Click Here to See the Profile for John W. TilfordClick Here to visit John W. Tilford's HomePageSend a Private Message to John W. TilfordEdit/Delete MessageReply w/QuoteDirect Link to This Post
RWDPLZ, Vintage-Nut, and Dennis LaGrua -
First, thank you!
Found the R6 compressor at Four Seasons at about $250 via provided link. Called their help number to ask if anything else should be replaced at the same time, thinking of high and low pressure release valves. Older guy (probably almost as old as I am) didn't mention the valves but said condenser, accumulator, and orifice tube. Said you'd risk burning out a new compressor without. Something about rings being hard to remove and jamming up.
This is looking more and more like 1) getting too complex, 2) expensive, 3) always doubt what to buy advice from a guy who works for a retail company, 4) ask for more Forum advice, and 5) wait until just before summer when need air conditioning.
I did find several sources for HR 6 compressors, new and rebuilt. But now I'm not clear regarding what other parts (new in 1987 for 1988 Fiero GT = old in 2025) should be replaced.
Thoughts?
John T
John W. Tilford
Vintage-Nut
Report this Post01-29-2025 05:09 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thoughts?
RWDPLZ is the A/C man, and last year I asked similar questions in this link...
Fiero A/C Questions
https://www.fiero.nl/forum/Forum2/HTML/147980.html
RWDPLZ
Total ratings: 305
Report this Post01-29-2025 07:11 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Accumulator ($50), orifice tube ($5), and o-rings ($20) at minimum. Switches will probably break when you remove them. Condenser would be a good idea, but good luck finding one.
A/C Parts list:
https://www.fiero.nl/forum/Forum2/HTML/000652.html
Report this Post01-30-2025 09:35 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Provided that the AC compressor is weak but still working, replacement work is not hard, As RWDPLZ pointed out you just replace a few items and O rings, then test for leaks, evacuate and recharge with the right amount of Ester oil and R-134A. Done right the A/C will blow ice cold.
Tools required: an R-134a A/C gauge set and an evacuation pump.
