  Ignition Panel Location Ideas
Ignition Panel Location Ideas by BruhMans06
Started on: 01-26-2025 08:01 PM
Replies: 5 (160 views)
Last post by: pmbrunelle on 01-27-2025 07:45 PM
BruhMans06
Report this Post01-26-2025 08:01 PM Click Here to See the Profile for BruhMans06Send a Private Message to BruhMans06Edit/Delete MessageReply w/QuoteDirect Link to This Post
The K swap is moving along and has been going quite smoothly, I am just about ready to get the engine back in the car.
Now Im starting to think about interior wiring. I bought an Instrument panel because I needed one anyway to run the engine on a stand, and I didnt want to go through rewiring the ignition switch on the fiero. My only question is where should I put it ?
I was thinking about where the radio is but I want to keep the radio. and I cant really figgure out where I want to put it.
help pls thanks
James Bird
Certified Idiot
1985 Fiero GT
Report this Post01-26-2025 09:17 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
help pls thanks
Make the mounting plate smaller, adjust locations of switches, put the power window switches on there, stuck out in where the window switches are (I don't think you could fit the mirror switch, if you have power mirrors)
CSM842M4
Report this Post01-26-2025 09:35 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Custom center console, put it in front of the shifter. I'm in the process of building such a custom console, hoping to put a cup holder or two in it, AND a few more switches...
BruhMans06
Report this Post01-27-2025 11:42 AM Click Here to See the Profile for BruhMans06Send a Private Message to BruhMans06Edit/Delete MessageReply w/QuoteDirect Link to This Post
Only issue I have with putting it on the center console is this thing is gonna be a manual, and I dont wan to accidentally switch the main off when shifting. I might just throw the plate out and just mount the switches and buttuns in different spots.
1985 Fiero GT
Report this Post01-27-2025 01:37 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
It wouldn't work for the larger switches, but I hot glued some switches in my driver's ashtray, hidden, but easily accessable at any time.
pmbrunelle
Total ratings: 63
Report this Post01-27-2025 07:45 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
If your Fiero doesn't have the rally gauge pod, you could install the pod and install your switches there.
