  Turbo Duke?
Turbo Duke? by 82-T/A [At Work]
Started on: 01-21-2025 09:47 AM
Replies: 14 (313 views)
Last post by: Dennis LaGrua on 02-10-2025 01:51 PM
Total ratings: 200
Report this Post01-21-2025 09:47 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, don't laugh... but here's a thought. My daughter took her Fiero to a car show for the first time (yes, her videos are way behind for anyone who watches them)... and she saw several cars with turbos on them. We plan to build another Fiero eventually, but she wanted to know if it was possible to add a turbo to her Iron Duke without modifying too much.
I'm just curious... are there any "really mild" turbo kits that one could add to a stock Iron Duke that perhaps could increase the horsepower around 15hp or so? Her Fiero actually runs amazing, by the way, way way quicker than any Iron Duke I've ever remembered owning. But I'm just thinking something that adds a couple of pounds of boost. Nothing crazy at all. She has more or less stock compression, but perhaps a little more since the head was planed.
Any thoughts?
I'm probably going to recommend against this, but it could be a good teaching moment to show her how it all works.
Report this Post01-21-2025 12:22 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Turbo Dukes have been built before. At one time there were two sources of Duke turbo charger kits ; IRM and Pfaff. They faded out with the introduction of the V6 and because owners went to far with them. By resetting the waste gate and jacking up the boost beyond the recommended 5 psi the engines blew up.
my opinion is that light boost will liven up things if used carefully and with a larger throttle body and a program reset or a boost ignition contoller..
IMSA GT
Total ratings: 250
Report this Post01-21-2025 12:25 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Honestly, have her save up and buy a Superduty motor. There have been many people on here who either added or bought a car with a turbo system. Most barely ran due to lack of tuning and the rest came apart under full throttle.
There is a person on Youtube who ran 18lbs of boost in his S-10 with the iron duke. He ended up with a lot of blow-by on gaskets and seals.
[This message has been edited by IMSA GT (edited 01-21-2025).]
cvxjet
Report this Post01-21-2025 12:33 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
They took the iron Duke way up the HP curve with CI and tuning mods....But I don't remember any turbo versions.
The big problem with turbos is turbo-lag....You give throttle (Nothing)...give it more throttle (Still nothing)....FLOOR IT!- and then it comes in hard and you lose control.
Back in 1988, I was sitting at a light waiting to make a left turn....88 Turbo T-bird comes up behind me and he starts revving his engine.....so the light turns green and I get on it thru the turn...look in rearview mirror...he's obviously trying to keep up....suddenly his rear slides to his right, then he over-corrects and turns the car hard right and he smashes into a tree!
I went back and asked if he was alright- He was pissed and stated I was keeping him from getting car home...Whole front end was smashed in and steam coming out of engine/radiator....
Build engine up or go with a belt-driven SUPER charger....
[This message has been edited by cvxjet (edited 01-21-2025).]
1985 Fiero GT
Report this Post01-21-2025 02:06 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wouldn't do it on the iron Duke, especially not on this Fiero, go crazy on the second, but it's nice to have an "original" Fiero, I would use a different/newer/stronger engine, that remains similar to what came in the car, I don't know if there are any like that for the iron Duke, but like how I'm using a 2004 3400 block and bottom end, Fiero heads and intake, looks original, practically is original, but it is stronger and can hold up to boost etc. I actually just tore down my 2.8, dropped the cradle, and pulled out my old 4 speed last night, and next day I work on it, I'll pull the block out, put my 3400 block and F23 transmission in. I've already picked a spot for the turbo, and gotten the intake/exhaust paths routed, and all this is with basic tools, a jack and jack stands, I got an engine stand so I could work on the new engine, but no hoists, lifts, etc, I manually lifted the block onto the floor jack to bring it up to the engine stand haha. I happen to have an f23 transmission now that has the ecotec bell housing, and I had the crazy idea of finding a junked Fiero (no engine/trans) and doing a f23/turbo ecotec Fiero, I think that would be a pretty fun engine in a Fiero, I'd do that if I wanted a 4 cyl turbo build, and would totally do that right now if I had money haha, which I don't!
Report this Post01-21-2025 03:04 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
This reminds me of a post I made ten years ago.
Originally posted by Patrick Here:
This past weekend I had the opportunity to drive a friend's ultra-expensive track prepared turbocharged 1999 BMW Z3 M Coupe at an autocross event. The engine in this car is supposed to be putting out 500 HP or so.
When the turbo kicks in... it's exhilarating. However...
The car and engine have been set up for high speed track use. The huge turbo on this engine doesn't do anything until 4000 RPM. It was frustrating as hell at autocross this past weekend as I'd be putting the pedal to the floor and screaming at the engine to do something! I'd be waiting up to two seconds for the power to arrive. Simply wasn't suitable for autocross.
I'm just mentioning this as it was my first experience driving a turbo-equipped car, and it was a little disappointing. Turbo size is obviously critical for a car used on the street and/or at autocross.
I emphasized the last sentence above, as I currently drive a JDM Subie with a correctly sized turbo from the factory, and it's a monster. Absolutely no turbo lag.
Having said that, I don't recommend that Todd wastes his time putting a turbo on a duke.
BruhMans06
Report this Post01-21-2025 10:10 PM Click Here to See the Profile for BruhMans06Send a Private Message to BruhMans06Edit/Delete MessageReply w/QuoteDirect Link to This Post
I personally wouldnt spend my time with putting a turbo in an Iron Duke, as they are already slow as is. The low RPM, and cast Iron build really really limits what kind of boost and how large the turbo can be. I like the idea of getting a v6 and swapping 3400 parts into one to get it up to speed to handle a larger turbo. Maybe even getting a whole new engine like a K series or LS, both of which respond to turbos really well but can be dangerous if you put too much power in them.
The problem with these old Iron block engines is that you really can put too much power into them. I saw a guy online put a John Deere turbo on an old iron block Midget, believe he pushed like 12 psi and ended up spitting oil out of the exhaust not even after 15 miles. The Iron Duke is probably in the same position. They are just built bad.
bottom line, the Iron duke is just not that great of an engine, and putting a turbo on it would definietly be risky.
I honestly think it would be a pretty funny project for shits and giggles. getting it to actually drive reliably would be sick.
James Bird
Certified Idiot
cartercarbaficionado
Report this Post01-22-2025 02:37 AM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
a good setup for a duke is actually an amr500 supercharger. I've ran 2 on a ford 300 to keep up with its Displacement spinning them halfway to lightspeedz however it's made for a 1 liter for for a fiero it might get you that 15 hp and be close enough. a better use of a duke would be to start from square one building for boost. like using the heavy duty block from a s10 and going with not cast pistons and a standard duty s10 crank. that setup with bolts should be able to handle 8 psi comfortably in theory.
the real solution is to build the duke up a bit to get her comfortable like getting a spare head and getting it ported, polished and shaved to bump compression and the bonus is it's a bolt on, the real limiter of the duke in the fiero is honestly the block though....very very weak as I've found out twice now with stock dukes
Report this Post01-22-2025 05:20 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just from memory, in 1984-1985, the Duke Pfaff Turbo kit boosted the power to about 130 crankshaft horsepower. on 5 psi of boost. That's a fairly low boost level. The engine had to have a larger throttle body installed to get more fuel and air to the engine. The ECM used a new program.. The problem with the kit is that some owners re-adjusted the waste gate to make higher boost and horsepower. This caused engines to fail. That and the introduction of the 2.8L V6 caused the kits to be discontinued. Hi-Tech turbo from IRM was the other source of the Duke turbo kits.
All said the cost and work involved in boosting the Duke to 130 HP is probably not worth the effort. There is a guy on You Tube that made 200 HP with a Duke engine and the crankshaft did not hold up. .
Mike in Sydney
Report this Post01-22-2025 05:27 AM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
One word: Nitrous (NOS).
A less expensive option for HP and near instantaneous throttle response. You can dial in the power by changing the nitrous jet. A 25 shot dry system would give a Duke around 30% more HP on demand.
mountainman
Report this Post01-24-2025 10:35 PM Click Here to See the Profile for mountainmanSend a Private Message to mountainmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well... I would love to put a Chrysler PT Cruiser turbo motor in a Fiero. Same basic configuration as the duke motor. 4 cyl. 5 speed. But, 170 to 225 HP. All day long. That's double the dukes power, no weight gain and factory style reliability. Just a thought. JM
Report this Post01-25-2025 12:05 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ideas and reality often do not coincide. Going outside the realm of swapping a non-GM engine into a GM car never designed for it, presents some really difficult challenges. It has been done before with intense fabrication and wiring for the most profound enthusiast. Even some GM swaps are hard to do so this job is far more that most would ever hope to do .
Total ratings: 200
Report this Post01-25-2025 05:12 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys, I'm just considering options... but I totally get what you guys are saying about Turbo and Turbo lag. Years ago, my wife had a 2002 1.8T Jetta. It was sluggish off the line, and then the Turbo would kick in and the tires would be burning rubber by the time I was already on the other side of the intersection (185hp version). It was the wildest feeling. I had the same experience with an RX-7 Turbo-2 from back in the day.
Definitely inconvenient when power comes on hard in the middle of a turn.
mountainman
Report this Post01-25-2025 11:08 PM Click Here to See the Profile for mountainmanSend a Private Message to mountainmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I agree with you Dennis. It would be tons of work. Mechanically I don't think it would be that difficult with the exception of the intercooler and designing a motor plate. Making it run would be the trick. Stand alone computer perhaps...
Report this Post02-10-2025 01:51 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just a general comment. With my 3.4L Turbo lag is hardly noticeable by using the correct size turbo, a cam with a turbo profile and a properly sized exhaust. For instance keeping the crossover pipe to a 2" size and wrapping it keeps the exhaust flow moving quickly and allows the Turbo to spool up almost instantaneously. Slam the pedal down and boost comes on quick. Its all a matter of designing the turbo system correctly.
