  Can someone identify if this clutch pivot position indicates that the clutch is stuck
Can someone identify if this clutch pivot position indicates that the clutch is stuck by RKZJ
Started on: 12-28-2024 08:47 PM
Replies: 14 (266 views)
Last post by: RKZJ on 01-02-2025 07:23 PM
RKZJ
Report this Post12-28-2024 08:47 PM Click Here to See the Profile for RKZJSend a Private Message to RKZJEdit/Delete MessageReply w/QuoteDirect Link to This Post
Title pretty well says it, I took this pic earlier today. I just installed Dickman's rear line repair kit so I've no idea if this is the engaged or disengaged position for the fork or not. If someone could chime in, it'd be much appreciated. This is an 88 gt 5spd. Thankyou.
shemdogg
Report this Post12-30-2024 10:04 AM Click Here to See the Profile for shemdoggSend a Private Message to shemdoggEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah thats stuck out for sure. Loosen the slave and the lever should come back. See if the pushrod got sideways in the slave bore and check for leaks.
shem
Report this Post12-30-2024 01:21 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is the piston corroded/stuck in the slave bore?
RKZJ
Report this Post12-31-2024 01:58 PM Click Here to See the Profile for RKZJSend a Private Message to RKZJEdit/Delete MessageReply w/QuoteDirect Link to This Post
shem
Negative to both, there is no pressure on the end of the brand new slave piston. It's almost as if the pivot arm is stuck engaged
RKZJ
Report this Post12-31-2024 02:00 PM Click Here to See the Profile for RKZJSend a Private Message to RKZJEdit/Delete MessageReply w/QuoteDirect Link to This Post
RKZJ
Member since Jan 2024
I just replaced it, the odd thing is it appears stuck disengaged but stuck. The pivot arm I'm able to get maybe a 1/4" movement in either direction and that's it
Report this Post12-31-2024 05:32 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by RKZJ:
I just installed Dickman's rear line repair kit...
... there is no pressure on the end of the brand new slave piston.
I just replaced it (the piston), the odd thing is it appears stuck disengaged but stuck.
So... it wasn't just the "rear line repair kit" that you installed?
Diagnosing from a distance is made all the more challenging when we're not being made aware of all the details. What all was replaced? Does the slave piston move smoothly all the way from the bottom of the bore to the top and back again (and/or vice versa)? And what was the position of the clutch arm prior to replacement of whatever slave components?
[This message has been edited by Patrick (edited 12-31-2024).]
RKZJ
Report this Post01-01-2025 12:37 AM Click Here to See the Profile for RKZJSend a Private Message to RKZJEdit/Delete MessageReply w/QuoteDirect Link to This Post
I installed the new slave after the rear line replacement yesterday after I posted the initial question. The piston wasn't even contacting the pivot arm, there's no pressure against the piston to have any stroke in the slave because there's nothing pushing it in. That goes for the first slave also, but given it's age a replacement should have been done. The clutch pedal is stiff because there's no pressure pushing back against it from the pivot point. That pivot has to come towards that slave piston. The only idea I have is that somehow it's either gone, or laminated to the flywheel at this point. Not sure how that could happen if the car was just sitting, which it obviously had been at the time of purchase.
The clutch arm pivot is in the same exact place as it was when I purchased it.
I was hoping someone would notice the distance off the arm was either clutch in or clutch out. It appears to be stuck engaged. Looks like now I get to find out if that's an engine out service or if there's access through the drivers wheel well.
Thanks for the reply.
1985 Fiero GT
Report this Post01-01-2025 02:30 AM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Look/stick a camera down to see the pivot for the clutch release arm, I don't know how common it is on what appears to be the later/cast arm, but on mine (85 stamped steel arm) cracked and rotated freely on the pivot, clutch fully engaged, but the arm rotated to the disengaged position
shemdogg
Report this Post01-01-2025 11:29 AM Click Here to See the Profile for shemdoggSend a Private Message to shemdoggEdit/Delete MessageReply w/QuoteDirect Link to This Post
The pressure plate should be pushing that arm back to the engaged position. Maybe someone did a clutch job and didnt line up the disc or pressure plate right and its all jammed together. Or the lever has slipped or was moved or broken.
shem
shemdogg
Report this Post01-01-2025 12:13 PM Click Here to See the Profile for shemdoggSend a Private Message to shemdoggEdit/Delete MessageReply w/QuoteDirect Link to This Post
shemdogg
Member since Apr 2017
I have a getrag sitting here for a swap and I took some pics for you
I found if I move the lever too far back, the TO bearing gets crooked in the shift arm lever thingie and doesnt want to retract
Dunno if that helps but now you know what the innards look like
shem
Report this Post01-01-2025 04:40 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
"it"... referring to the car? Do we understand then that you've never driven this Fiero, that it's never had an operational clutch while you've owned it? Getting the full picture on this situation is like pulling teeth!
[This message has been edited by Patrick (edited 01-01-2025).]
RKZJ
Report this Post01-01-2025 10:54 PM Click Here to See the Profile for RKZJSend a Private Message to RKZJEdit/Delete MessageReply w/QuoteDirect Link to This Post
shem
Thank you so much, this was what I was asking for, I can clearly see my lever is indeed all the way to the passenger side stuck in the clutch engaged position. It would be plausible it may have gotten stuck being hyperextended, but honestly who the heck knows lol.
Thank you for your time again sir.
[This message has been edited by RKZJ (edited 01-02-2025).]
RKZJ
Report this Post01-01-2025 11:02 PM Click Here to See the Profile for RKZJSend a Private Message to RKZJEdit/Delete MessageReply w/QuoteDirect Link to This Post
RKZJ
The car has not had a working clutch since I purchased it. It has sat for some time, I observed a leak at the coupling between the braided and hardline section,
ordered the repair kit and a new slave. I first installed the repair kit, bled it with the old slave and observed 0 travel and the piston at full extension. The slave came in, I vac bled the system after installing it and same thing.
Should be some better clarity for you.
Taking a look at the pictures posted by the other member, it does appear the lever is locked in full extension, actually a little past it, so at my next availability I'll visually inspect it for cracks at the connection point to the pivot shaft and probably hit it with a little heat to see if that gets it going.
Thanks for your help.
shemdogg
Report this Post01-02-2025 11:12 AM Click Here to See the Profile for shemdoggSend a Private Message to shemdoggEdit/Delete MessageReply w/QuoteDirect Link to This Post
Youre probably gonna have to drop the cradle and get it apart to see whats going on. In the first pic it looks like someones used a lever to try and push the arm back. I see the foil wrapping dented. Its not hard to pull the cradle, then again I do it often lol.
shem
RKZJ
Report this Post01-02-2025 07:23 PM Click Here to See the Profile for RKZJSend a Private Message to RKZJEdit/Delete MessageReply w/QuoteDirect Link to This Post
shem
From my searching that does appear to be the direction to proceed. The plan was to swap this anyhow, I've been meaning to build one of these for 25 years, and seeing the the transmission options are still what they are, I'll be searching more lol.
Thanks for your help shemdogg. Off to Copart to get hosed on a crashed car with no LSD looks like
