  Clutch pedal plastic piece
Clutch pedal plastic piece by saving_rossi
Started on: 12-14-2024 11:47 PM
Replies: 4 (132 views)
Last post by: saving_rossi on 12-16-2024 12:02 AM
saving_rossi
Report this Post12-14-2024 11:47 PM Click Here to See the Profile for saving_rossiSend a Private Message to saving_rossiEdit/Delete MessageReply w/QuoteDirect Link to This Post
I recently received a clutch and brake pedal assembly from an eBay seller. It was terribly packaged, and very dirty. I wouldn’t have minded if a plastic rod by the clutch pedal was not snapped.
I worry that this is the piece that triggers the master cylinder. The plastic piece that the plastic rod connects to has a plug in…I think this is to allow to car to start once the clutch is pushed in? I’m doing an auto to manual swap so maybe I wouldn’t need that piece anyway.
I just wanted to ask here to make sure. Should I be worried if this plastic piece is broken?
Total ratings: 461
Report this Post12-15-2024 01:27 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
saving_rossi
Report this Post12-15-2024 02:05 AM Click Here to See the Profile for saving_rossiSend a Private Message to saving_rossiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Patrick:
Forgive me I’m still learning some aspects of how the actual clutch hydraulic system works. It came broken so it was hard to tell what it was meant to do. By your response I’m going to assume it has nothing to do with it
Total ratings: 461
Report this Post12-15-2024 02:46 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think you were describing the neutral safety switch. Check out my recent post Here in regards to not utilizing one.
saving_rossi
Report this Post12-16-2024 12:02 AM Click Here to See the Profile for saving_rossiSend a Private Message to saving_rossiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you!
