  How to Remove Coolant Plug from Head (V6)
How to Remove Coolant Plug from Head (V6) by robmox
Started on: 11-29-2024 02:42 PM
Replies: 7 (224 views)
Last post by: Notorio on 12-12-2024 11:22 PM
robmox
Report this Post11-29-2024 02:42 PM Click Here to See the Profile for robmoxSend a Private Message to robmoxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello, everyone!
I'm working on an engine swap, and I'm nearing the finish line.
My next big issue is that the machine shop put what appears to be the temperature sensor in the head and the coolant plug for the head in the wrong spots. I went to remove the coolant plug (I have a set of plumbing coolant plug wrenches), and it wouldn't budget. I cranked on it with the breaker bar, and then tried the breaker bar. I'm afraid to put heat on it.
But, does anyone have suggestions for how to remove this coolant plug from the head?
Alternatively, I may just rewire the plug for the sensor and route it back to the front of the engine. The one issue with this is that the coolant pipe runs right past it and it looks to be in the way.
Let me know your thoughts.
The plug in question:
The sensor:
The coolant pipe that impacts the sensor:
Total ratings: 200
Report this Post11-29-2024 07:41 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by robmox:
Hello, everyone!
That plug is really hard to remove. I think you already know, but the coolant plug "socket" is just a 3/8" socket extension. The best way to remove that is to slowly work the plug back and forth. Sounds crazy, but work it back and forth (meaning, tighten it, and then loosen it). Tightening it helps break the threads free in the other direction. It likely has some thread locker on it, including sealer as well. Just keep working it back and forth until it starts to break free. No real easy way to do it other than to take the whole head off and send it off to a machine shop.
Report this Post11-29-2024 07:50 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I suspect at some point in that engine's life, the heads were removed (with the temperature sensor and coolant plug already in place)... and then reinstalled on the opposite sides of the engine.
[This message has been edited by Patrick (edited 11-29-2024).]
sleek fiero
Report this Post11-29-2024 08:44 PM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you heat the plug with a propane torch and then let it cool it will destroy thread locker/sealant and shrink the plug. Also sometime hitting with a punch that fits in the hole for the wrench will help break the threads free. sleek
Report this Post11-29-2024 09:07 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's a common situation when swapping in a 3.4. The plug and temp sensor are in opposite heads than the Fiero. Fortunately, that was caught on my swap, so the heads were removed, new head gaskets installed, and the heads were swapped from side to side. If you can get a 3/8 drive impact extension and an impact, a little tightening and loosening as 82-T/A described. Maybe a little heating and cooling, too.
cliffw
Total ratings: 292
Report this Post11-30-2024 10:41 AM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
Absolutely. Tighten a tad first, and then loosen a tad the other way. Again in that procedure just a little bigger tad. I learned this from an ASE certified lifelong mechanic friend of mine. In my case, I broke a bolt head off using a bigger hammer, and had to drill a hole dead center (mine was a 90o drilling operation in tight quarters), then use a tap and die set.
Another option is to use an impact wrench. I can not find my hammer blow driven one but it applied just one impact per hammer strike. You can use a cordless one but don't keep impacting in only one direction.
fierosound
Total ratings: 286
Report this Post12-02-2024 12:21 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sometimes a THERMAL SHOCK with a product like Freeze Off can help break it loose.
https://www.fiero.nl/forum/.../HTML/140257.html#p0
[This message has been edited by fierosound (edited 12-02-2024).]
Notorio
Report this Post12-12-2024 11:22 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rob, please let us know what worked (or didn't work) for you ...
