So, this guy tells me a story about some guy from Michigan, who used the computer box out of a 1993 Chevy Beretta to increase horsepower in his 88 Gt to 250. He stated that the process involved changing the stock EGR to an electronic one, and disconnecting the cold-start injector. Anybody ever heard of this before? Is it somewhat legit or just snake oil? Thanks for any input.
Shortly after the Fiero V6 was built, a racer by the name of Herb Adams decided to dyno test the engines. He tried making numerous changes to the program timing and fueling. After trying many combinations no power increase was made by altering the chip program. Herb reported that the GM engineers did their job well. What did work was the porting of the restrictive exhaust manifold that gave an extra 5-7 free horsepower.
Snake oil? More like BS. If it was possible, the members of this forum would be all over it.
250HP is 110GHP more than stock. You might be able to do it with a 110 shot of nitrous - once. After that...?
I'm hard pressed to understand why changing the EGR to a electronic unit (how would that work, anyway) or disabling the cold start valve which if I understand it correctly only operates during the cranking cycle when the engine temp is below 95°.
That's known as the 7730 ECM conversion. I'm using the NA$T1 code mask with supports up to 8400 rpm. I currently make 211 rwhp using a heavier drivetrain than stock, so hypothetically I am making 250 hp. It's a 3.5L iron head engine. It's still not running perfect so I do expect to make more power. Also, I'm still on 93 octane with octane booster. Once I go E85 it should make closer to 240rwhp.
So it's not impossible, just requires a lot of unmentioned investment.
Without looking for my old bookmarks, or searching, doesn't the 7730 conversion yield a smoother idle and provision for a knock sensor?? Of course one can't do this in California because the digital EGR would fail the visual test.
On any otherwise stock motor, you could gain a couple of horsepower by having custom programming to optimize the fuel mapping... but you wouldn't really gain any peak horsepower since things like EGR (if I'm not mistaken) are shut off during wide open throttle anyway. I think 93 was the last year for MPFI, and they went to SFI the year after, or maybe SFI started in 1993. You gain better around-town performance, but again... no increase in peak HP. Going with a newer ECM though should improve some drivability issues that tend to get exacerbated when the car gets older.
A brand new Fiero though never had hunting idle or hesitation at any RPM.
I am still amazed at California emission testing. Guys doing visual inspection today weren't even born when the Fiero was produced. Would it be the end of the world if we stopped emission testing after a car hit 25 years old or something?
I'm not an expert, but I think most states that do have emissions testing, likely have some rules that a car is less scrutinized once it reaches a certain point. Sometimes it's combined with other things like getting a classic car designation (which brings with it different / lower insurance premiums since you wouldn't be driving it as much).
But yeah... I'd imagine, if the car is meeting emissions requirements (tailpipe sniff), why do they care then if the original equipment is on there?
Here in BC, after many years of emission testing of all vehicles, it was determined that there were so relatively few older "polluting" cars still on our roads, that the high cost of running the emission testing program was no longer justified. So although I'm all for clean air, I fully supported the BC government's decision on this.
[This message has been edited by Patrick (edited 09-17-2024).]
in north carolina you can do whatever you want to a fiero as long as you don't attract a cop.NO inspections.over 35 years old.
Same in NJ; no inspection is required on cars 25 yrs and older. Just don't have a loud exhaust that will wake up the dead. Most of the older classic cars are classified as historic and they don't get driven very often. The only time that I see these older cars is at cruise nights, car shows. NJ inspection on newer vehicles just requires a look at your OBDII readings No trouble codes and you pass
In Florida... no inspections, anywhere, ever... for anything... whether the car is a year old, or 100 years old. You can put whatever you want in it...
Missouri has no emissions after 28 years... Which is a weird number, but makes classic cars easier to get legal. Still have to get a safety inspection in Saint Louis but I've heard it depends on the county.
