  Heater hose
Heater hose by Kennyr29
Started on: 07-29-2024 10:39 PM
Replies: 7 (177 views)
Last post by: cartercarbaficionado on 08-03-2024 04:03 AM
Kennyr29
Report this Post07-29-2024 10:39 PM Click Here to See the Profile for Kennyr29Send a Private Message to Kennyr29Edit/Delete MessageReply w/QuoteDirect Link to This Post
I received a 88 fiero formula. Previous owner pulled the engine and cut the heater inline hose. Is there any guide on how to reroute line or buy one.
Report this Post07-30-2024 06:42 AM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
google is your friend.
metal or the rubber line?
Total ratings: 200
Report this Post07-30-2024 07:48 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi, the Fiero Store has ALL the replacement hoses for your car...
http://www.FieroStore.com
Kennyr29
Report this Post07-30-2024 11:25 AM Click Here to See the Profile for Kennyr29Send a Private Message to Kennyr29Edit/Delete MessageReply w/QuoteDirect Link to This Post
It's the rubber hose from the t stat housing down
Total ratings: 200
Report this Post07-30-2024 11:36 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
So, all the hoses for the V6 88 Fiero are located here: https://www.fierostore.com/...rowse.aspx?d=152&p=1
Kennyr29
Report this Post08-03-2024 12:00 AM Click Here to See the Profile for Kennyr29Send a Private Message to Kennyr29Edit/Delete MessageReply w/QuoteDirect Link to This Post
It's the rubber line
jelly2m8
Total ratings: 242
Report this Post08-03-2024 01:48 AM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
That's a rubber line that's hard clamped / crimped to the car's hard line, your options are to get that rubber hose from any 87-88 V6 car or use heater house and route it to fit, that you should be able to do. One can cut the lower crimp and salvage the hose, or remove the f'd up one and use a regular hose clamp to replace.
BTW, the previous owner is an Idiot.
[This message has been edited by jelly2m8 (edited 08-03-2024).]
Report this Post08-03-2024 04:03 AM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
standard (I think 1 inch? mine is at least but use a ruler and guess how wide the barbs are) heater hose should work just fine. only recommendation is to use either steel reinforced or fiber reinforced and non worm gear clamps or use 2 per hose barb 180 degree offset from each other to clamp In a circle so once tight they shouldn't loosen again. also wrap it in aluminum foil tape as it helps shield the hose from the exhaust heat quite well
