  Broke down code 35
Broke down code 35 by jumpmonkey
Started on: 07-29-2024 09:14 PM
Replies: 5 (166 views)
Last post by: Matthew_Fiero on 07-30-2024 06:19 PM
jumpmonkey
Report this Post07-29-2024 09:14 PM Click Here to See the Profile for jumpmonkeySend a Private Message to jumpmonkeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Recently got the engine running on my 85' GT after sitting for 20ish years. Seemed to be running ok other than an audible vacuum leak.
Took it on a test drive and was fine for the most part cruising around under 30mph, although the gas pedal seemed a bit stiff. After trying to speed up a bit on a level road, I shifted into what I believe was 3rd gear and the car died. Didn't pass operating temperature.
I let it cool down for a minute and started her back up again. No codes.
Turned around to head back home and it died again after driving for around another minute. This time it would not start back up. Towed it home and have code 35 getting thrown at me 3 times. Any ideas on where to go from here?
I had planned on replacing all my vacuum lines and my EGR Valve/Tube.
Jumpmonkey
Report this Post07-29-2024 10:20 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you look Here?
Code 35 - Idle Speed Error
The ECM will set code 35 when the engine speed is 75 RPM above or below the correct idle with closed throttle. This condition must be met for at least 45 seconds before the code is set. If idle speed is too high, check for vacuum leaks. If idle speed varies up and down, your engine might be running too lean (high air/fuel ratio). Check for low fuel pressure or water in fuel. If idle speed is too low, your engine might be running too rich (low air/fuel ration). Check for high fuel pressure or leaking/sticking injectors. Also, check all connections to the IAC and replace the IAC if necessary.
jumpmonkey
Report this Post07-29-2024 10:39 PM Click Here to See the Profile for jumpmonkeySend a Private Message to jumpmonkeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Patrick:
Did you look Here?
[QUOTE]
I did look over that description. I wanted to see if anyone has gotten this code at the same time as their vehicle breaking down. I'm not sure what could've been so extreme to cause the failure.
Report this Post07-29-2024 10:44 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Failing fuel pump (or splitting "rubber" hose in tank) causing a lean condition, before failing completely? Or it could be something entirely unrelated to a Code 35, such as a failed ICM.
You need to check for basics, such as fuel pressure and spark.
Dukesterpro
Report this Post07-30-2024 11:16 AM Click Here to See the Profile for DukesterproSend a Private Message to DukesterproEdit/Delete MessageReply w/QuoteDirect Link to This Post
Im with Patrick.
Ignore the code till you check your basics. Spark. Fuel, Timing. Lets see what you are missing first
Matthew_Fiero
Total ratings: 51
Report this Post07-30-2024 06:19 PM Click Here to See the Profile for Matthew_FieroSend a Private Message to Matthew_FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
How old was the gas? Could affect fuel injector performance if the fuel is gummed up.
