  Best spark plug wires?
Best spark plug wires? by CSM842M4
Started on: 07-08-2024 05:32 PM
Replies: 8 (246 views)
Last post by: fierosound on 07-10-2024 08:29 AM
CSM842M4
Report this Post07-08-2024 05:32 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yesterday I started changing the spark plugs on our '86 2.5 5-speed. Did not finish, because the wire tore off and out of the plug-end terminal and boot on the #2 wire, and the boot started to tear on the #3. I stopped at the front two plugs before things got any uglier. So, I am prepared (tools and experience) to roll my own wires from a kit. Does anyone have information on build-em-yourself plug wire sets, either really great ones to work with even after they're installed or ones to run screaming from because they're so crummy? Thanks in advance - Chris
cartercarbaficionado
Report this Post07-08-2024 06:19 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
had good luck with the orielly yellows that are 5 years old on a big block olds and before that I had them on a ford 289 v8 so those are alright but go very heavy on the dialectic grease on the boots. you can't have too much on the boots they give since they shrink overtime.
no personal luck with autozone ones but that's probably because I kept melting them on my blazer trying to replace the custom rat chewed oriellys custom length ones It had
fierosound
Total ratings: 287
Report this Post07-08-2024 06:20 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've been more than happy with MAGNECOR KV85 plug wires on both my cars.
They have sets for Fiero Duke and 2.8 V6 listed in Catalog
https://magnecorusa.com/performance/
[This message has been edited by fierosound (edited 07-10-2024).]
Report this Post07-08-2024 11:59 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Making wires often don't last better then made by most factories.
Making wires is only way to get new for some old or custom vehicles & some race engines.
Making them right is more complicated then many think. Example: Many use generic crimp tool that crimp ends too tight or loose & ends Fail sooner then pre-made.
Magnecor 7mm is enough for most users but there web store say no 4050, 4750 or 4550 so need to email etc,
Vintage-Nut
Report this Post07-09-2024 09:33 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
The factory spark wires are 7mm.....If you want to use the stock plastic spark wire dividers, don't buy 'bigger' wires.
A Recent Thread on the Subject:
Spark plugs & Wires by Yellow-88
https://www.fiero.nl/forum/Forum2/HTML/147780.html
CSM842M4
Report this Post07-09-2024 02:37 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks to all who have chimed in so far. All valid concerns, ogre. But after messing up on my first couple of sets, 40+ years ago, my MSD terminal crimper has folded countless terminals on as many feet of wire flawlessly. Since those first two sets, I've not had a wire fail due to a faulty crimp or improper assembly. What I HAVE had is enough wire sets "made to fit" that would not work right out of the box that I would just as soon build my own from a set that would let me get the length and routing correct. As to the dividers/retainers, I'm spending enough time on the lathes and milling machines at work that I believe I could make my own for whatever wire diameter I want to use.
By the way, fierosound, those engine rooms are beautiful works of art! Your own work?
Vintage-Nut
Report this Post07-09-2024 04:00 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
CSM842M4:
Wow, this is an understatement - "Hats Off" for fierosound!
Report this Post07-09-2024 06:05 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Both of those engines look absolutely amazing!!!
fierosound
Total ratings: 287
Report this Post07-10-2024 08:29 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you! You bet!
Click the links below...
