| | | quote | Originally posted by IMSA GT:
So back to the very first post. What was your goal here? Retrofit Solstice knuckles? |
I never posted what i was up to…
Flipping the upper ball joint (if it works) gets the ball joint spread down to about 9.5”. 88 spread is about 8.5”. Happy with that. The tie rod end gets flipped upside down, and looks like it will be pretty close too. Am about to weld in new ball joint sleeves in the lower control arm. Solstice/corvette lower ball joints instead of those rodney 1” drop joints. Sad about modifying an 88 part. Also, the solstice knuckles raise the hub position (drop the car) about 2” 😬
The ackeman angle ideas that started my thread.
Fiero knuckles sorta look like rear steer knuckles flipped around to front steer. I should have thrown the car on the alignment rack and measured it!
Be a couple weeks before i can get back to any of this.
[This message has been edited by ricreatr (edited 07-13-2024).]
