Can anyone tell me which "direction" the Rear Main Seal should be pressed in?
I know it's directional in order to direct the oil back into the block, and that the crank turns clockwise from the front, which I assume to mean counter-clockwise in the back.
The rear main seal (new one) is hollow on one side (exposing the seal-spring), and closed on the other. I can't find anything that tells me which way it should be pressed in.
Thank you!
hollow side faces crankshaft pulley 99% of the time for the rear main will look at my 84 iron duke at some point to tell you if it's different than everything else
The only application that I've ever been aware of where an engine's rear main oil seal was mounted "backwards" was on a water pump. We installed two rear main oil seals on those engines... the inner one was installed the regular way, and the outer one was installed "backwards", to assist in preventing water from being forced past the regularly mounted oil seal and into the crankcase.
Thanks Jelly, I appreciate it... that makes sense. It concurs with my timing cover seal, which also did not have any instructions and I had to "assume."
And Patrick... in this case, there's nothing obvious to tell me which direction it gets pressed in. It could literally go in either way. It should be relatively obvious, but no arrow or anything... not even instructions, which I find totally weird.
The "obvious" indication is that the seal-spring goes (as far as I know, always) on the pressurized side.
I'm not sure what you mean... the seal-spring is dead smack in the middle... it's just that one side of the seal is open, the other side is closed. But it would seal it regardless of which direction you pressed it in... but the flap that the spring holds down has little /////// on them which are designed to carefully guide the oil back into the engine... and that really dictates which way it should be properly pressed in (otherwise it'll fail quickly).
It would make sense to me that the open side should be in, but I've never read anything that told me so...
... it's exactly the opposite of a freeze plug of course, in which the open side goes out, and the closed side goes into the block... lol.
Todd, you're supposed to pay attention to those things when you tear it apart.....
Joe, we've torn the ENTIRE car apart. We took 100s of pictures. Every screw was bagged and labelled, and lots of pictures... and tons of manuals, but this one thing wasn't covered in any of the manuals.
... I guess we DO technically have a video of it...
But shoot you guys are a tough crowd. I appreciate that you guys think so highly of me that you expect me to know these answers already... but I took a 14 year hiatus from working on cars. I'm ok looking like a complete idiot so long as everything gets done properly. Anyway, I wouldn't have asked... but I searched literally everywhere, and this was the closest thing I could possibly find that even slightly gave me an answer... https://www.scegaskets.com/...r-Main-Seal-Inst.pdf
... and that's for a two-piece rear main seal that doesn't get pressed in.
Originally posted by 82-T/A [At Work]: Joe, we've torn the ENTIRE car apart. We took 100s of pictures. Every screw was bagged and labelled, and lots of pictures... and tons of manuals, but this one thing wasn't covered in any of the manuals.
We do that frequently enough in the shop that there are very few times we have to refer to FSM's for guidance. Hope you didn't mind me busting your chops a bit....
No, thanks, I appreciate it. But it goes to show... even when you think you've accounted for EVERYTHING, there's still some things you might miss. We took tons of pictures, and even have a spare engine to pull a few parts off of (such as if one bolt is too rusty, and we want a nicer one). This is one of the things we missed.
Kind of interesting, but other than the year-to-year improvements on the engine... there were a bunch of other things that changed too, just on parts alone. Like, even the spark plug loom holders... in the 84-... ? 86 maybe? They had loom clips all the way around the valve cover in case it the wires would be wrapped on one side or another. But in 87 (or at least i know for a fact in 88), they removed most of the little clips. There's a bunch of little things like that, even the brackets changed year to year.
