| quote | Originally posted by richard in nc: i will add that the oil sender is excessively hard to get to on a 2.5.even with the muffler removed i could barely reach the harness to the oil sender. |
This make No sense.
I've replace a lot more on 2.5l then the OP sender & had enough room to get @ them from the top.
Sometimes I remove a heat shield on the trunk wall to get more space to remove parts.
But often have to work by feel because hard to see w/ Intake manifold & related parts in place.
⚠️ if working w/ the air cleaner off, Cover the screw(s) w/ heavy rag so you don't hit it/them or drop crap in the TBI.
Even pulled valve lifters w/o removing the intake or the alt.
May Need to remove the ignition & OP Sender to clear the cover to get it out.
Does help when have special socket for 88 sender but not very hard to mess w/ that w/o the socket.
Socket is extra long 1 1/16" socket to fit the odd shape.
Example:
https://www.amazon.com/gm-o...essure+sensor+socketOld sender has 9/16" "nut" can get w/ short wrench.
⚠️ Not all things are Metric. Most sensors/senders are "SAE" Treads & tools to install them. (Threads are actually NPT same as any U.S. Pipe parts.)
