| quote | SunsetChaser: Sounds like a way to go {rebuild} if it's not too involved. |
Obviously, rebuilding your distributor will take more effort than replacing it with a 'new' unit. And clearly as Patrick pointed out, replacing the archaic 'prong' design with the newer 'star' design IS better.
| quote | SunsetChaser: Mine's pretty rusted out.... |
No, your distributor is not "pretty rusted out" - look at
Patrick's photo in this thread!
https://www.fiero.nl/forum/Forum2/HTML/146823.htmlIf your O-ring
isn't leaking oil at the base, "why" replace/rebuild it?
If you want to replace it for other reasons:
You want the 'easy' way out; you want ACDelco but refused the remanufactured newer 'star' design and are complaining on prices of vintage/classic parts?
Your choices are either purchase a unit (ACDelco or Aftermarket) OR rebuild the original V6 distributor.........
BTW - I can send you a step-to-step procedure IF you want to rebuild and good luck in your decision
[This message has been edited by Vintage-Nut (edited 05-19-2024).]
