Yes, correct rad cap is a must.
See
https://web.archive.org/web...erocave/coolcaps.htmDon't trust the dash gauge. Get a ECM scanner or other way to get correct temps.
Pipes may not be crushed but still have crap plugging the rad etc.
Rad plugged is easy to check using IR thermometer & look @ bottom & top tubes.
Bottom tubes often will get plugged first then doesn't do anything & stays cooler then top tubes.
If "dirt" is blocking, flush may help but plugged Aluminum Radiators often means tubes are "rust" plugged & any method of flushing won't work.
When filling after flush etc, Do Not use Premix coolant.
See
https://web.archive.org/web...erocave/coolfill.htm------------------
