I have an 88 formula that the trunk lock is totally ******** up. Is there any way to access the trunk other than cutting a hole in the bottom. If there is please let me know. Thanks.
The whole cylinder is missing. Stuck a big screwdriver in to see if I could price something to pop it open and couldn't get a hold of a thing. Any suggestions appreciated.
A long standard screwdriver with a head of about 1/4" will pop the trunk. It will fit into the slot in the lock easily. Shine a light into the lock hole in the decklid so you can see the slot in the lock mechanism.
ironically this is how I opened it on my formula for awhile. best one you can use is a 5 inch (or longer) shaft with a 1/4 inch end (mine was a hacked up chainsaw one that was labeled as a #9) but be aware if it is fully closed you will need to apply downwards force to the decklid to make it easy or just twist pretty hard to get it to turn enough to open properly. also a few taps to make sure it's seated real nice ain't gonna hurt it as long as you don't whole hog it. if anyone messes up their lock rod (he's gonna need to remove it if not already gone) I do have a template around somewhere for cutting one out of 1/4 bar stock that can also be used for the power solenoid
Thanks to all who replied. And Olejoedad small Screwdriver method did the trick. Which goes to show you that bigger isn't necessarily better. At least in screwdrivers.
But again I would like to thank all that replied and I really appreciate your help.
