| quote | Originally posted by cvxjet: I decided to try this- return the left-caliper parking brake lever to it's original position...and then test-drove and brakes work perfectly now.
Don't understand how turning that PB actuator screw 1/6 a turn could make the brakes feel spongy- OK, maybe at first- but after bleeding multiple times I would think the hydraulic brakes would work correctly.... |
Rotating the parking brake lever pulled the piston too far from the rotor.
Pedal travel was used to close the gap, which will feel spongy.
By rotating it back, you closed the gap and now the rear brakes work like they should.
The rear calipers are hydromechanical and the self adjusting feature takes a long time to work.
