| quote | Originally posted by fierofool:
Could a PO possibly have changed them? My 85GT had the metal clips and posts. I replaced them with some 87 coupe windows with plastic posts and FieroSails GT inserts. I just drilled the holes in the body flange to a little larger size. But, if you want to use a window with metal pins, just slide the clips in place over the larger holes. |
It seems possible, but that panel was cracked, looked as old as the car, the Pontiac arrowheads were also certainly original, the holes look original to, no scratches around them, rough drilling, etc. Perhaps somehow mine was made very late in the year, like a mid year transition? Interestingly enough, the Fiero store says that only 84s had metal clips under the listing for replacement plastic ones.
