I am about to install a new master cylinder....previously, I have done MC replacements on a number of cars....Normally bench-bleed the MC via small hoses recirculating fluid up into the open top before installation...but the info on my new Fiero MC states "Let fluid drip out of pipe fittings, then pump MC to make sure it is working properly"
Which way do you guys go? (drip....fill...pour....what-EVer) |
The way I do it tends to be really, really slow.
I'll bench bleed it a little bit, to try to get as much in as I can, but I don't like brake fluid leaking out, so it usually doesn't work out very well.
In the end, I usually end up bleeding all of the calipers completely... which granted, is a lot of fluid. And a lot of it gets wasted. But I'll do the entire car. Just takes a while, but then you can be sure you've got all new fluid through the entire system. I just keep checking the reservoir to make sure it doesn't run low and suck more air into it.
