See
https://web.archive.org/web...cast.net/~fierocave/ crush pipes
If looks sim to that,,,
loose front nut to frame, drop hangers under rocker panel then see if can move the pipe.
Maybe not since heater & water pump hoses are short.
If not need the remove the hoses that likely means have to dremel cut wheel to cut Al crimp "clamp" for small hose.
Cut the pipe thru the crush zone, restore the shape, then use plain hose to seal.
Must support both parts & tie the back to the car so pressure won't push it out of the new hose.
WHILE hose joints have Bumps etc to prevent that. cut pipes don't SS makes near impossible to add them w/ DIY methods. Like most solder & glues won't stick to it. Some may seem to stick but isn't & fails sometime later.
If is more to front, Remove the front nut & likely the rad hose to get more room & likely leave back hoses in place.
Restore shape might be able to exhaust pipe expander to finish the job.
Doesn't have to be exact, round enough to get good flow & hose can seal.
