Hi, i'm looking for some help with the AC on my 3800 conversion. I have a 2003 GTP motor and PCM installed and have everything wired correctly as far as I can tell. Using Torque Pro, I can see that the PCM is reading 80psi on the ac pressure sensor. The issue I have is that the PC is not providing the ground to engage the compressor relay. Beyond the AC request and correct pressure signals to the PCM is there anything else it requires to engage the compressor?
C203 D to AC relay coil Lt Blue and PCM Clear 22 AC Request C203 N to AC relay Blk Wht AC relay Dk Grn to AC compressor clutch PCM Clear 39 AC Compressor Clutch Rly to AC relay coil AC Pressure Sensor Power to PCM Clear 34 AC Pressure Sensor Signal to PCM Clear 27 AC Pressure Sensor Ground to PCM Clear 35
When I turn on the AC the engine cooling fan kicks in and the engine idle speed adjusts, so it seems that the PCM is seeing the AC request signal. I have 12v at the ac clutch relay coil and power terminal. If I jump the power to clutch terminals on the relay the clutch engages. I'm seeing 80psi from the pressure sensor in the PCM according to the Torque scanner. The PCM output Clear 39 is not closing to provide a ground for the relay coil. Could there be another input the PCM is looking for to allow the compressor output to turn on?
Your other wiring is correct, per my diagrams. The light green and blue wires at the dessicator connector need to be tied together to eliminate the cycle switch on the OEM Fiero harness. It should work fine after that change is made.
I bypassed the cycle switch and still have the same result(there is enough pressure in the system to cause that switch to be closed). I checked all of the wires again and everything looks correct. For some reason I’m not getting the pcm output ground to activate the compressor relay.
Not sure where to go from here. Maybe try another PCM?
The service number on the PCM is 12209624 YCZS. I had it reprogrammed to remove VATS, the rear O2 sensor and EGR, I'll contact the person that programmed it to see if he has any thoughts. The pressure sensor is attached to a T fitting on the high pressure line and the pressure reading in the PCM matches my gauges.
