  Check Engine Light when Applying the Brakes
Check Engine Light when Applying the Brakes by Rightasrain
Started on: 03-24-2024 10:15 AM
Replies: 18 (392 views)
Last post by: fieroguru on 11-09-2024 10:02 PM
Rightasrain
Report this Post03-24-2024 10:15 AM Click Here to See the Profile for RightasrainSend a Private Message to RightasrainEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi All,
I have a 3800 series II swapped 87 GT with a stange issue and any idea will be much appreciated.
As the post title suggests I get a check engine light when I apply the brakes.. The CEL is like a 4'th brake light since it goes away quickly when releasing the brakes.
Has anyone encountered this?
Thanks,
Ronen
Report this Post03-24-2024 03:05 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The first thing that comes to my mind is a wiring issue at C203 connector.
The CEL light and a lead from one of the brake switches both go to that connector.
The C203 is located under the center console, below where the OEM fire ECU lives.
C203-C is wired to the CEL light
C203-P is wired to the brake switch
I don't know if this is your problem, but it might be a place to start.
Rightasrain
Report this Post03-25-2024 12:34 AM Click Here to See the Profile for RightasrainSend a Private Message to RightasrainEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks a bunch, super helpful!
I will check this out and update shortly.
Rightasrain
Report this Post04-13-2024 01:57 AM Click Here to See the Profile for RightasrainSend a Private Message to RightasrainEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dug deeper and all wires/connections at C203 look solid.. I did some checking around the brake pedal switch and it is not the brake switch triggering the SES light but the TCC switch next to it.
Additionally, I'm getting a P0341 code which I thought was a different issue all together but I have no idea anymore.
Any advice would be welcomed really.
Thanks,
Ronen
jelly2m8
Total ratings: 242
Report this Post04-13-2024 03:50 AM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
it's a wiring issue, follow oldjoedad's advice.
P0341 is camshaft position sensor code, irrelevant to your brake light, but possibly you have an unrelated issue.
[This message has been edited by jelly2m8 (edited 04-13-2024).]
Report this Post04-13-2024 07:16 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The TCC switch on the brake pedal should be wired to C203-P.
If its wired to C203-C that is your problem.
C203-C should be wired to PCM C2-5 (clear). It is a brown/white wire.
[This message has been edited by olejoedad (edited 04-13-2024).]
Report this Post04-23-2024 10:45 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does it happen when your parked w/ transmission in neutral/park?
Or only when Driving?
If only when Driving...
Is likely Wiring problems that angry from iffy motor/trans mounts letting the engine pulling or pinching the wires.
Or bad exhaust melting the wires now then soon can cause a fire.
Rightasrain
Report this Post04-23-2024 10:54 AM Click Here to See the Profile for RightasrainSend a Private Message to RightasrainEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for responding!
It happens in all trans gears and when the car is both on or off..
[This message has been edited by Rightasrain (edited 04-23-2024).]
Report this Post04-23-2024 03:43 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you check the wiring at C203?
Rightasrain
Report this Post06-11-2024 03:50 AM Click Here to See the Profile for RightasrainSend a Private Message to RightasrainEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry for the delay, quick update.
Checked the wiring and it all looks fine
I have replaced the ICM since I have a P0341 code and once the new ICM was installed the check engine light when braking went away. Really weird...
I still have the P0341 code after a 15 min drive which is a world of pain. New hitachi coils, New Standard ICM etc.
Still trying to sort out the electrical gremlins...
Rightasrain
Report this Post11-08-2024 06:10 AM Click Here to See the Profile for RightasrainSend a Private Message to RightasrainEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi All,
Sorry to resurrect this but I would like to provide a summary of my pursuit of this gremlin.
The check engine light when pressing the brakes was due to the gearbox being overfilled with oil. My "genius" mechanic dumped a bucket load in there and after I've drain it to the correct level all is well.
The P0341 is most probably caused by the ICM/CPK/CPS harness, seems OK for now after replacing it, let's hope it killed it.
Cheers guys
Report this Post11-08-2024 06:35 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow, after all these years here, nothing much is "new"... but that is! Although I don't understand the connection between a CEL and too much oil in the tranny, thanks for reporting back.
[This message has been edited by Patrick (edited 11-08-2024).]
cyrus88
Report this Post11-09-2024 02:19 AM Click Here to See the Profile for cyrus88Send a Private Message to cyrus88Edit/Delete MessageReply w/QuoteDirect Link to This Post
. . . once the new ICM was installed the check engine light when braking went away. Really weird...
The check engine light when pressing the brakes was due to the gearbox being overfilled with oils . . .
So, was it the ICM replacement or the gear oil? I'm confused.
[This message has been edited by cyrus88 (edited 11-09-2024).]
Rightasrain
Report this Post11-09-2024 04:22 AM Click Here to See the Profile for RightasrainSend a Private Message to RightasrainEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry for the confusion, I got excited finally getting it solved.
I had two issues, main one, which is subject of this thread, was my "4th braking light" which triggered the CEL when pressing the brakes. This was due to too much in the gearbox which created high oil pressure.
Second issue was a P0341 which I thought was somehow connected. It wasn't. It was the ICM harness.
All is well for now, finally
Report this Post11-09-2024 09:37 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the check engine light was coming on with the key off and brake pressed, then it is related to the brake switch wiring. The ecm can't activate a DTC and turn on the check engine light with the key off. The brake light circuit is one of the few circuits that has power while the key is off.
While overfilling an automatic transmission isn't good for it, it won't link the check engine light to the brake pedal.
I suspect you still have a wiring issue with some worn insulation between the brake wires and the check engine light wires. The issue went away because the wires are no longer touching, but the issue hasn't been "fixed".
[This message has been edited by fieroguru (edited 11-09-2024).]
Report this Post11-09-2024 04:31 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
The OP referred to it as a "gearbox" which leads me to believe it's a manual transmission... but nowhere in this discussion does he actually make it any more clear.
[This message has been edited by Patrick (edited 11-09-2024).]
Report this Post11-09-2024 09:29 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
He mentioned TCC, which only exists on automatics. He also referenced pressure, and Fiero manual transmissions do not generate pressure, but automatics do as well.
Report this Post11-09-2024 09:45 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ah, I missed that one reference.
However, automatic transmissions (as well as manuals) do not generally trigger a CEL ... so it was difficult to make total sense of this thread.
Report this Post11-09-2024 10:02 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Its OK, you can try to do better next time!
