  Rear mainbearing seal
Rear mainbearing seal by Lombok
Started on: 03-16-2024 06:53 AM
Replies: 2 (92 views)
Last post by: jelly2m8 on 03-17-2024 12:46 AM
Lombok
Report this Post03-16-2024 06:53 AM Click Here to See the Profile for LombokSend a Private Message to LombokEdit/Delete MessageReply w/QuoteDirect Link to This Post
1987 V6 Leaking rear main seal I have a small groove in the crankshaft. Am I out of luck. Thank you in anticipation. Lombok
Frenchrafe
Report this Post03-16-2024 07:10 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
See if you can get a repair sleeve?
I used one on a 3800 crank that was scored. Hasn't leaked since.
Link to RockAuto:
https://www.rockauto.com/en...+repair+sleeve,10524
"Turbo Slug" - '87 Fiero GT. 3800 turbo. - The fastest Fiero in France! @turboslugfiero
https://youtu.be/hUzOAeyWLfM
[This message has been edited by Frenchrafe (edited 03-16-2024).]
jelly2m8
Total ratings: 243
Report this Post03-17-2024 12:46 AM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Link to RockAuto:
This, put many a repair sleeve on a number of different engines through the years, all have lasted and been reliable, I install them using Loctite Green 290.
I work at a lot of marine Diesels that their only mission is to get worked hard 24/7, and these repair sleeves have saved hundreds of thousands in repairs for my customers.
[This message has been edited by jelly2m8 (edited 03-17-2024).]
