Another tire/wheel question. It probably has been answered a hundred times but there are so many tire threads that searching through them
would take days.
So, to be concise. I want to put a boosted 3.8 Pontiac V6 in my 1985 Fiero. During the process I want to upgarde the stock wheels and tires also.
Wheels will be used ones because I can't just go out and spend a bunch of $$ on new wheels. I have a list of cars that have a 5x100 bolt circle so I will refer to that list.
As an addemdum to what I just said, Pontiac offered 5x100 wheels on several models that they produced including; Grand Am, Phoenix, Sunfire, Sunbird,
Tempest, Vibe, 2000, and 6000. Do any of these cars feature wide rims? You can see the complete list by going to:
www.stocktonwheel.comFirst question regarding wheel size. I am thinking of using 16" wheels because 17" wheels that fit will need a very low profile tire. And I do not
like the look of really low profile tires on this car. Will running 16" wheels buy me much in that regard? Is there still a large selection of 16" sport
tires on the market?
What is the preffered offset for wider tires front and rear? Since I am planning to use a 3.8 I want to put some wider tires on the rear especially.
Regarding this, the car will be a road car influenced car and not a drag car. Will running skinnier tires in the front and wider in the back mess up the balance of the car?
I am thinking it might make the car turn-in more rapidly. Would wheel spacers help correct this if put in the front? Usually road racer type sedans use
equal width tires on all 4 corners.
What are the limiting factors affecting wheel rub in the front and in the back? Will coil overs allow wider tires/wheels in the back? How about the front?
Thanks in advance for any and all well considered suggestions.
Randy
