  Fixing stereo wiring
Fixing stereo wiring by Lowerit
Started on: 12-01-2023 10:25 PM
Replies: 1 (331 views)
Last post by: 1985 Fiero GT on 12-02-2023 09:24 AM
Lowerit
Report this Post12-01-2023 10:25 PM Click Here to See the Profile for LoweritSend a Private Message to LoweritEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm returning my fiero to the stock radio and had some questions about wiring. The car previously had a pioneer deck installed by me sometime around 2000. Sadly the original harness was cut, thankfully I have a replacement Metra stock harness I'm in the midst of putting in. I just wanted to clarify some wiring colors after spending time searching the forum.
Fiero Speakers
RR + DK Blue
RR - LTBlue
LR + Brown
LR – Yellow
LF + Tan
LF – LT gray
RF + LTGrn
RF – DrkGRN
12V Constant ORANGE
12V Switched ?
Ground Black
Remaining unknown wires
2 Pink wires
1 yellow and black
1 gray and black
It appears as though the installer pulled a switched 12V wire right from the fuse block, but I'm not keen on this if I can avoid it.
I'm going to put a modern bluetooth stereo in , but want to start with a stock harness and make a proper adapter - Hence the desire to return it to stock. Thanks!
JM
1985 Fiero GT
Report this Post12-02-2023 09:24 AM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is a graphic I found to help me do the same thing that you are doing
It is accurate, at least everything works on my 90s Pontiac radio!
