  2 Speed to Single Speed Fan Switch
2 Speed to Single Speed Fan Switch by BruhMans06
Started on: 11-29-2023 11:19 AM
Replies: 3 (451 views)
Last post by: fierosound on 11-30-2023 11:24 AM
BruhMans06
Report this Post11-29-2023 11:19 AM Click Here to See the Profile for BruhMans06Send a Private Message to BruhMans06Edit/Delete MessageReply w/QuoteDirect Link to This Post
So ive run into an issue as I was reinstalling my wiring harness onto my 2.5. I had to replace the engine I had since the person who owned it before me caught the engine on fire, and the replacement i bought is a 1985 engine. I haven't had any issues with the electronics since I swapped the distributor and other miscellaneous electronics that are specific to the 1984 engine.
So i need a new fan switch, and its a 2 speed since my car is an 84' 2m4 with AC, but the cable looks weird and the switch also looks weird. I cant seem to find a 2 speed switch that will fit the plug but i can find tons of single speed switches.
Is there an easy way to convert it to a single speed, or is there a place i can find a 2 speed switch?
Thanks much!
James Bird
[This message has been edited by BruhMans06 (edited 11-29-2023).]
Total ratings: 202
Report this Post11-29-2023 02:49 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks much!
Hi James, I could be wrong, but what you're looking at is actually the engine temperature sensor, not the fan switch. The fan switch (sensor) looks like this for all years:
What you probably need is this from the Fiero Store, so you can use the newer sensor: https://www.fierostore.com/...px?s=61899&d=169&p=1
But if you want to get the original sensor for the 84 model year, you can get that here: https://www.rockauto.com/en/moreinfo.php?pk=941150
Report this Post11-29-2023 07:01 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, Above is not a fan switch or gauge/light sender.
Is ECM sensor & installed wrong. That Sensor need to be in T-stat tube.
84 Rad Fan uses 2 switches. See https://web.archive.org/web.../~fierocave/fans.htm
fierosound
Total ratings: 287
Report this Post11-30-2023 11:24 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 2-speed fan switch for the 84 Fiero is unique (and hard to find?)
On my 84 Indy I changed to a single speed switch like the later years.
http://rodneydickman.com/pr....php?products_id=235
I wired the switch to the Lt Green/Black wire (left other disconnected at switch)
[This message has been edited by fierosound (edited 11-30-2023).]
