  3800 series3 sc swap
3800 series3 sc swap by FerioEd
Started on: 11-17-2023 04:40 PM
Replies: 6 (396 views)
Last post by: Darth Fiero on 11-22-2023 08:13 AM
FerioEd
Report this Post11-17-2023 04:40 PM Click Here to See the Profile for FerioEdSend a Private Message to FerioEdEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi , I'm Ed from north Alabama. I just recently bought an 87 Gt with a rod knocking. It is the 2.8 with Auto trans. I am wanting to do a 3800 sc swap . I have found a series 3 from a 2005 Gran Prix with 120,000 miles on it. It is just the motor, Wiring harness has been cut when engine was pulled. i have searched the forums and see that i would have to run it as a series 2 and change tb. My question is what do I need get the auto transmission ,wiring harness series II PCM from.
Spoon
Total ratings: 61
Report this Post11-18-2023 06:21 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Why not keep it as a series III. You'll have to replace your accelerator pedal for an electronic version to work the series III throttle body. Find a ECM and tranny from a Series III as well. You'll need a custom harness, built by others on this forum, to make everything work.
I did the Series II with 4 speed conversion. It was a piece of cake. "A child could do it".
Others will chime in, hold your hand and walk you through along the way as needed.
Spoon
[This message has been edited by Spoon (edited 11-18-2023).]
Total ratings: 328
Report this Post11-19-2023 04:20 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
We've done a couple of Series 3 swaps but always used the N* throttle body that is cable operated. This required using the 2003 PCM to shift the tranny. No earlier PCM will shift the 03-up transmissions. So in essence we used Series II control.
As Charlie said you could do a full series three swap using the accelerator pedal module and keep the electric throttle body but some serious reprogramming of the PCM might be required. The later 3800 systems were used in conjunction with traction control and I believe wheel sensors. I don't know if that's the best route to performance but a good programmer should be able to help you with a work around. Good luck on the swap, you'll love it.
FerioEd
Report this Post11-20-2023 11:03 AM Click Here to See the Profile for FerioEdSend a Private Message to FerioEdEdit/Delete MessageReply w/QuoteDirect Link to This Post
Might be a dumb question but are your saying it has to be a 2003 pcm. So a 2000 or 2001 auto transmission, ecm and pcm and wiring harness will not work with a series 3 motor
Total ratings: 207
Report this Post11-20-2023 01:43 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you have a 2000-2001 4T65e-hd trans, you can use the series 2 wiring harness and PCM with the series 3 engine.
You should use a cable operated throttle body with the setup.
Contact me via PM for more details and information.
[This message has been edited by olejoedad (edited 11-20-2023).]
FerioEd
Report this Post11-20-2023 06:43 PM Click Here to See the Profile for FerioEdSend a Private Message to FerioEdEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok Thanks. PM sent (I think)
Darth Fiero
Total ratings: 361
Report this Post11-22-2023 08:13 AM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you did not get the 4T65E auto trans from the same 2005 Grand Prix you got the series 3 engine from, then NO, you do not necessarily need a 2003 PCM. You only need a 2003 PCM if you are using a 2003-up 4T65E transmission, due to some electronic changes GM made in 03-newer 4T65E transmissions.
If you end up using a 2002-earlier 4T65E trans, you can use a 97-02 PCM (although I would avoid using a 97 PCM specifically due to some issues those PCMs had as well as their rarity.)
In any case if using a 2003-earlier PCM with a Series 3 engine, you will need an adapter plate that allows you to substitute a cable-operated throttle body in place of the Series 3's stock drive-by-wire unit. ZZP and a few other vendors sell such plates.
-Ryan
More is more. Less is not enough.
[This message has been edited by Darth Fiero (edited 11-22-2023).]
