| | | quote | Originally posted by gregr75: mines an 87gt. i believe 88 was different from 84-87 as far as cable routing. |
Yes.
Above is about right. GM had 2 wire clips/guides to keep the cables contacting exhaust or handing down too far but most are missing now for many reasons.
OE clip setup are shown in other "books" including 86 87 (page 5-14 5-13 respectively.) Fiero FSM.
They are not tight & move some as you pull/release the lever. GM use Wire but other things can work but may not last. Example: Tie Wraps may work but most fail exposed to heat, oil, UV, & more depending exact ones used.
Longer clip Hard to see in FSM etc. Goes to a slot on bottom of the cradle then hooks to the main cable to keep away from the exhaust parts.
One is "S hook" was to tie up the "equalizer" that I rework to ties main to left wheel cables to keep main away from the exhaust. If you keep both @ GM location, can add the extra support here like Small hose clamp left lose will do.
the cable will be happy as long as don't touch the Exhaust pipe or clamp. Between heat & vibration the E-clamp can try to saw thru the cable.
But @ same time, don't pull it onto the cradle edge tight for same reason because cable need to move.
If you're worried about heat after that. use same heat block tape for wires. RD & others sell that.
Main cable has support "clamps" where goes over the left wheel parts but someone made the above one.
They don't need a tight clamp, just something to keep away from axle etc.
