  Does the Fiero use those grey plastic / nylon door striker bushings?
Does the Fiero use those grey plastic / nylon door striker bushings? by phils88GT
Started on: 11-02-2023 03:55 PM
Replies: 5 (297 views)
Last post by: 82-T/A [At Work] on 11-04-2023 09:10 AM
phils88GT
Report this Post11-02-2023 03:55 PM Click Here to See the Profile for phils88GTSend a Private Message to phils88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am new to the Fiero world. My 88 GT does not have the door striker bushings, and I was wondering if they are supposed to and have just broken off over the years.
If they are supposed to have them, anyone have a part number?
Thank you again,
Phil
IMSA GT
Total ratings: 253
Report this Post11-02-2023 08:20 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I assume you're talking about this? If so, it does not have a bushing.
[This message has been edited by IMSA GT (edited 11-02-2023).]
phils88GT
Report this Post11-02-2023 08:31 PM Click Here to See the Profile for phils88GTSend a Private Message to phils88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's the one! My driver side one looks a little chewed up. I guess it is time to replace.
Thanks!
Spadesluck
Report this Post11-02-2023 11:17 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks!
Do a search for door strikers. There is another option other than the stock striker
Total ratings: 154
Report this Post11-03-2023 08:38 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
If that striker is chewed up, your door hinge pins are worn out and the door is sagging. It will only happen again if you don't replace the hinge pins.
Get them here: https://www.fierostore.com/.../Detail.aspx?s=69505
Report this Post11-04-2023 09:10 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you again,
Phil
When my Fiero was basically "new" ... I was the 3rd owner, but the car only had 47k miles on it, and the car had sat in storage for over a decade as it passed hands between two CIA employees that had taken overseas assignments, and didn't get to drive it much. It was an 87 that I bought in early 96. So it was only 9 years old with 47k miles on it... and both doors had those plastic sleeves. So they are original... but they do wear out (intentionally). The doors tend to sag over the years, so you'll want to rebuild the door hinges, and THEN replace those bushings (as Fiero Fool said).
