  86 SE not starting
86 SE not starting by Stilltrack80011
Started on: 10-17-2023 01:01 PM
Replies: 20 (260 views)
Last post by: Jake_Dragon on 11-11-2023 10:24 AM
Stilltrack80011
Report this Post10-17-2023 01:01 PM Click Here to See the Profile for Stilltrack80011Send a Private Message to Stilltrack80011Edit/Delete MessageReply w/QuoteDirect Link to This Post
My 86 SE is not starting, First we thought it wasn't getting gas, so I changed fuel filter while also changing the fuel lines a couple times (it kept leaking so fuel is at least going through the fuel pump), I've put a new distributor with a new cap and ignition coil, new ignition wires and spark plugs, it started once before and ran but when I put it into drive it just died out and haven't gotten it started since, that was after changing the distribution and all that but before changing the fuel filter, at this point I'm all out of ideas
Edit: it is the 2.8 v6, automatic, my bad for making y'all guess
Zavier Myers
[This message has been edited by Stilltrack80011 (edited 10-18-2023).]
Total ratings: 207
Report this Post10-17-2023 01:35 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have spark?
Stilltrack80011
Report this Post10-17-2023 01:44 PM Click Here to See the Profile for Stilltrack80011Send a Private Message to Stilltrack80011Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, when I changed the spark plugs, ignition wires and distributor, the only problem we was having was the timing, but I got that figured out and it started running, but that was when I put it in drive and it just died out
Total ratings: 403
Report this Post10-17-2023 02:24 PM Click Here to See the Profile for Jake_DragonSend a Private Message to Jake_DragonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Air, Fuel and spark
Suggest getting a fuel pressure gauge and checking fuel pressure.
The fuel pump is located in the gas tank, there is a rubber compression connector between the fuel pump and the hard line. They age and can split. This causes low pressure and if it gets bad enough will cause the car not to run.
Bypass the fuel relay and turn on the fuel pump to test pressure
https://www.fiero.nl/forum/Forum2/HTML/144192.html
Check for codes
https://www.fiero.nl/cgi-bin/main.cgi?ECMCodes
Car could die when shifting into drive if the TCC solenoid is bad.
You can unplug the connector and try again but this alone wont stop the car from starting just when shifting into drive.
https://www.fiero.nl/forum/...110502-2-099983.html
https://www.fiero.nl/forum/...050119-2-055302.html
Welcome to the Forum.
Cliff Pennock
Administrator
Total ratings: 699
Report this Post10-17-2023 04:25 PM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
When you turn the ignition on (without starting), can you hear the fuel pump come on for 1-2 seconds?
Stilltrack80011
Report this Post10-17-2023 04:38 PM Click Here to See the Profile for Stilltrack80011Send a Private Message to Stilltrack80011Edit/Delete MessageReply w/QuoteDirect Link to This Post
Air, Fuel and spark
Check for codes
I'll have to try those when I have the time again, thanks
Stilltrack80011
Report this Post10-17-2023 04:40 PM Click Here to See the Profile for Stilltrack80011Send a Private Message to Stilltrack80011Edit/Delete MessageReply w/QuoteDirect Link to This Post
Stilltrack80011
Member since Oct 2023
When turning it on, the fuel pump does activate, but I've been slowly killing the battery and I don't have a charger at the moment, using it on a different car
Total ratings: 465
Report this Post10-17-2023 05:40 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Stilltrack80011:
...the only problem we was having was the timing, but I got that figured out and it started running, but that was when I put it in drive and it just died out
So you had the ALDL jumper in place while you used a timing light?
buddycraigg
Total ratings: 478
Report this Post10-17-2023 09:23 PM Click Here to See the Profile for buddycraiggSend a Private Message to buddycraiggEdit/Delete MessageReply w/QuoteDirect Link to This Post
What engine?
Total ratings: 465
Report this Post10-17-2023 09:35 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
What engine?
We're supposed to guess.
I suspect it's the 2.8... but you never know!
Stilltrack80011
Report this Post10-18-2023 01:20 AM Click Here to See the Profile for Stilltrack80011Send a Private Message to Stilltrack80011Edit/Delete MessageReply w/QuoteDirect Link to This Post
No, but during that time, when we was putting the distributor in my grandpa was helping me with it and he rebuilt the engine beforehand, told me that as long as it was very close, it would start and run, run bad but it would run
Stilltrack80011
Report this Post10-18-2023 01:23 AM Click Here to See the Profile for Stilltrack80011Send a Private Message to Stilltrack80011Edit/Delete MessageReply w/QuoteDirect Link to This Post
Stilltrack80011
It is the 2.8, my bad for not Specifying
Total ratings: 465
Report this Post10-18-2023 02:16 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
...as long as it was very close, it would start and run, run bad but it would run
Why not do it properly? All you need is a paper clip... and a timing light of course.
buddycraigg
Total ratings: 478
Report this Post10-18-2023 04:21 AM Click Here to See the Profile for buddycraiggSend a Private Message to buddycraiggEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you hear the fuel pump run for a few seconds when you first turn on the key, then we will assume the fuel system is working.
Do you have a timing light to verify the ignition system is working?
Total ratings: 207
Report this Post10-18-2023 06:57 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
No,.....
(snip)
That's your problem.
The ECU is adjusting the timing, the ALDL must be jumpered to time the engine.
Good question Patrick.
ArthurPeale
Report this Post10-18-2023 12:30 PM Click Here to See the Profile for ArthurPealeSend a Private Message to ArthurPealeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I thought all SE were the 2.8
Arthur Peale
Total ratings: 403
Report this Post10-18-2023 02:15 PM Click Here to See the Profile for Jake_DragonSend a Private Message to Jake_DragonEdit/Delete MessageReply w/QuoteDirect Link to This Post
After replacing the Distributer you have to get it close.
Find TDC and adjust the distributer so spark plug one is pointed to the number one plug on the distributer. That should get you close enough so the car will run then you can use the timing light to get it set correctly after its running with the jumper in place.
Finding TDC is the trick. You can pull the valve covers and watch the intake valve and verify the timing mark is correct. Pull the spark plug and use a soft rod and slowly rotate the crank until you know you are at TDC
Setting your initial timing will get you in the ball park until you can get it running and timed correctly.
Balancer marks can shift that is why its important to verify TDC and not just trust the mark on the balancer.
https://www.youtube.com/watch?v=O8H54pKeNEc
its a SBC but its the same process.
Good luck
Total ratings: 465
Report this Post10-18-2023 06:26 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is incorrect... which is why it ticks me off when people state they have an SE and expect us to know what engine they have. It's not a GT. It's not a Formula.
fierosound
Total ratings: 287
Report this Post10-19-2023 12:46 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
The piston is also at TDC on the exhaust stroke...
I pull spark plug #1 and stick my finger in there as I manually turn engine with ratchet/socket.
When I feel the pressure building, I bring the timing mark up to 10* on the pointer. Reinstall plug.
(you could use a compression tester if you have one)
Then I remove distributor cap to make sure the rotor is pointing to #1 plug wire and they are in correct order 1-2-3-4-5-6
Always starts
(unless it's a fuel or ECM issue)
[This message has been edited by fierosound (edited 10-19-2023).]
Spoon
Total ratings: 61
Report this Post10-23-2023 07:46 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just make sure it not like these. Results may vary.... Hint... plastic coated.
[This message has been edited by Spoon (edited 10-23-2023).]
Total ratings: 403
Report this Post11-11-2023 10:24 AM Click Here to See the Profile for Jake_DragonSend a Private Message to Jake_DragonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did it start? Anticipation is killing me..
