| quote | Originally posted by theogre:
I see... I Rarely see 84-85 car to look at them. Is likely a "fancy" jam switch to prevent snags on cloth etc.
The Jam Switch I linked works the same but May Not fit there. Not sure if the Nut will clear right even if the Sleeve adjust correctly first time you shut the door.
The switch is black so it blends in with the black door frame.
And the smooth plunger prevents clothing snags as you suggested.
NW-Fiero's best bet is parts from someone with an 84-85 parts car. Lots around.
He should post a "looking for" ad in The Mall.
Nearest wrecker to him is in Lynnwood, WA (430 miles is to me, not him)
[This message has been edited by fierosound (edited 09-03-2023).]
