  How hot does auto transmission oil get?
How hot does auto transmission oil get? by Cliff Pennock
Started on: 08-12-2023 08:16 AM
Replies: 11 (217 views)
Last post by: Dennis LaGrua on 08-13-2023 08:11 PM
Cliff Pennock
Administrator
Total ratings: 699
Report this Post08-12-2023 08:16 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Trying to find a hose I can use to repair the transmission lines near the radiator. Most hoses I find can withstand the oil but are rated to about 100C (212F). Would that be enough?
Total ratings: 328
Report this Post08-12-2023 08:37 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Transmission oil in a vehicle can be as low as 160*F but in rare cases can go as high as 225*F. My Fiero typically sees trans oil temps in the 165* area. While the Fiero has a trans cooler in the radiator it is a small one but the long lines leading to the front IMO may help somewhat. You can use an infrared pyrometer to check the temps.
Spoon
Total ratings: 61
Report this Post08-12-2023 08:49 AM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cliff, consider an external transmission cooler. Just google "External transmission cooler". I've used them as far back as the Original GTO days when converting from manual trans to automatic. Plus its external of the radiator so no chance of coolant being preheated to some degree.
https://transmissioncoolerg...ransmission-coolers/
https ://www.amazon.com/Hayd...84001431364292&psc=1
https://www.amazon.com/EVIL...Z2V0TmFtZT1zcF9tdGY& psc=1
Spoon
[This message has been edited by Spoon (edited 08-12-2023).]
Report this Post08-12-2023 10:06 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Read the Cave.
The Heat Exchanger is in the Hot Side of the Rad to Maintain AT Heat.
Is "wrong" to say "coolant lines" etc because is Not a Cooler Many Times but nearly everyone says Cooler...
Because is only a Cooler when Oil is Hotter the Engine Coolant. It Heats the Oil when cooler than the Engine Coolant temp. Engine Cooling Temp is often above 100°C/212°F in hot side tank.
Most Aftermarket Coolers are installed wrong and cooler the Oil to much and Oil doesn't get hot enough to do it's job. More so since w/ most AT have TC Locking because Unlocked TC make most of the heat. Lock TC removes 80-90% of heat generated and drive in cool to cold weather the Trans Oil get Too Cold.
Other hoses may say can handle oil still Fails carrying AT Oil and not just the Heat.
Oils have different Base Formulas to start then add whatever Additives and "hate or love" rubber/plastics they touch.
J1532 TOC (Trans Oil Cooler) hose is made to have Dextron Mercon and other AT Oils.
That often Fails carrying other oil and petrol more so petrol w/ ethanol and other alcohol.
Total ratings: 207
Report this Post08-12-2023 11:34 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Ogre is correct on all accounts in the above posting.
Total ratings: 202
Report this Post08-12-2023 01:29 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
In the two Fiero fires I've had... both were as a result of failing transmission coolant lines. First was an 84 Fiero that had not been "highway driven" for almost 5 years (just short distances). It split and shot a steady jet of transmission fluid directly on the catalytic converter... I created a smoke screen on the highway, and only noticed because no one was passing me for several minutes... hahah....
But keep in mind that there's apparently a point to having the transmission line "loop" on one end (can't remember if it is out to radiator cooler, or back in from radiator cooler); however... I knew at one point (hopefully someone mentioned above), but you don't want to lose it. It had something to do with air in the line, or preventing it, or... I have no idea, I just remember someone telling me it was really important to ensure you maintain that. I think there's even a little holder that's supposed to maintain that loop.
(someone correct me on this please, would like to know...)
Cliff Pennock
Administrator
Total ratings: 699
Report this Post08-12-2023 03:45 PM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, but like I said in the other post, I can't get that hose here. So I need to find a hose by specs.
Total ratings: 202
Report this Post08-13-2023 12:10 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Wouldn't any automatic transmission line that you buy in the Netherlands also work? I wouldn't imagine they'd be too different. Just get something that's meant for an older pickup truck I'd think... and bring some of the old rubber transmission line with you.
Cliff Pennock
Administrator
Total ratings: 699
Report this Post08-13-2023 07:07 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oddly enough, hoses are never marked as "suitable for transmission oil". I in fact went to a parts store and when I asked for a rubber hose suitable for transmission oil, they said they didn't have any and were not aware if it even existed. I checked quite a few Dutch car forums and apparently, people use hydraulics hoses to replace transmission lines. So that's what I ended up ordering. It can withstand pressures up to 5000psi, temps up to 212*F, and should be suitable for transmission oil.
Total ratings: 202
Report this Post08-13-2023 12:45 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
That's pretty smart... I mean, I guess that's literally what it actually is!
sleek fiero
Report this Post08-13-2023 04:59 PM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cliff try a hydraulic shop.they work with hot hydraulic oils all the time and I am sure they can recommend a good hose for a low pressure transmission line. sleek
Total ratings: 328
Report this Post08-13-2023 08:11 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Read the Cave.
Whether I refer to it as a heat exchanger or a cooler, if it keeps my trans fluid from rising above 180* (my thermostat rating) then IMO it has accomplished its purpose. It seems to be around 180* most of the time. The long metal lines under the car exposed to an air stream as you drive may act to cool the trans fluid somewhat. As over 90% of automatic transmission failures are caused by burning the clutches I want to keep the transmission from overheating..
