  Stereo System to Replace stock system on 1988 GT
Stereo System to Replace stock system on 1988 GT by rebeck02
Started on: 08-02-2023 03:55 PM
Replies: 22 (463 views)
Last post by: richard in nc on 08-19-2023 06:07 PM
rebeck02
Report this Post08-02-2023 03:55 PM Click Here to See the Profile for rebeck02Send a Private Message to rebeck02Edit/Delete MessageReply w/QuoteDirect Link to This Post
Can anyone suggest a reasonably priced / decent quality stereo system with a CD player to replace the stock system in a 1988 GT? Thank you. reb (Roger)
Total ratings: 463
Report this Post08-02-2023 06:36 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you can find an early nineties Pontiac Monsoon system, you'll need a harness adapter, and an antenna cable adapter. Then you're golden.
replacementradios.com sells the adapters. (They used to sell the radios, too, but seem to be sold out.)
[This message has been edited by Raydar (edited 08-02-2023).]
Vintage-Nut
Report this Post08-02-2023 09:06 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check-out Crutchfield / '88 Fireo
https://www.crutchfield.com...tfitmycar/mycar.aspx
Report this Post08-02-2023 09:41 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Raydar:
If you can find an early nineties Pontiac Monsoon system...
CLICK FOR FULL SIZE
Raydar, where do you jam the CDs into on that model?
cvxjet
Report this Post08-02-2023 11:37 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
The one that Ogre has posted is an older version with cassette....the later version has the CD...And there is a guy in the Mall the sells them (When he has some) modified to allow iPod connection. (Fiero Tom- second page of Mall postings); https://www.fiero.nl/forum/Forum4/HTML/075303.html
[This message has been edited by cvxjet (edited 08-02-2023).]
Report this Post08-03-2023 12:14 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Used and many "restored"/"rebuild" car radios may work now but soon dies because many parts in them are on the "last leg."
Example: 20+ year old capacitors die because cabin heat when park outside often see 150-200°F and best caps hate that. GM and most other never use best parts in most things in a car.
Old CD DVD and BRay units often also Optical problems.
Inside the "head" have "mirrors" and lenses w/ metal coating and metal reacts w/ air & crap and is Dead, Very Dead, and no DIY or "Pro" will be able to reflash those parts right. Some parts look to be Mirrors but isn't. It/they are beam splitters and must have correct coatings or is Dead.
I've lost count for dead CD/DVD units just for PC and most of them dies in 3-5 years often for same reason.
Is very likely part of why replacementradios.com etc no longer carry radios for 80's & 90's cars.
Even if they get enough units to sell... Hard time selling "cheap" and replacing a lot of old caps and other parts. Worse, some other 30 year old thing break soon and have "warranty" problems costing more money.
Several GM units I have worked when put in storage no longer even turn on.
MarkS
Report this Post08-03-2023 01:53 PM Click Here to See the Profile for MarkSSend a Private Message to MarkSEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thing about the Fiero is the radio size. It is a DIN 1.5 size. Most "affordable" new CD players are single DIN size: https://www.crutchfield.com...&nvpair=AG_Type|ffCD Adapters are available but I myself never liked how they looked in the Fiero.
I've done the later model GM players shown above and they worked good but agree they can be finicky, especially the volume controls crapping out. I've done something like this https://www.ebay.com/itm/175671549087 just a used deck, not modified like this one. Worked good but the lighting was not red like this guy shows and was bluish, didn't look great at night. I replaced it with and earlier model Pontiac CD player from a TA that looked almost identical to the stock cassette deck. That worked & looked nice, it went with the car when I sold it. I might still have the CD deck with the bluish lighting if your interested for the cost of shipping. It hasn't been used in years and have no way to test it now. PM me if interested.
If I were to do it again, I'd go this way: https://www.retromanufactur...riant=41987652124828 you could get a used CD changer for the trunk to use with it.
lou_dias
Report this Post08-03-2023 03:01 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
the problem with those mid to late 90's 1.5 DIN stereos is the power/volume knob constantly malfunctions.
I can't currently turn one of my units on.
There was yet a newer version released 1998-2002 that is 1.5 DIN and looks a little different that is more reliable.
It can be seen here:
https://www.ebay.com/itm/295646566938
There's a CD and Monsoon version as well if you look around.
[This message has been edited by lou_dias (edited 08-03-2023).]
css9450
Total ratings: 86
Report this Post08-03-2023 03:29 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
My 88 has one of the fancy UX1 radios and I had to send it to a place in Saginaw Michigan for repairs, but it's been perfect ever since. It was expensive, but worth it since I'd rather have that then some ugly aftermarket radio that doesn't match anything.
Mike in Sydney
Report this Post08-05-2023 07:09 PM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dang, Ogre, to quote Oddball from Kelly's Heroes,
Rebek02 (OP), I got three Fieros and all have the Pontiac Grand Prix,7-band equaliser AM/FM/CD player. I've had two over 7 years and have had them modded to accept an input from an external source. All three are over 25-years old and I've never had any problems. They look stock which is good because in my state of New South Wales my cars carry Historic Registration. To qualify, you can't have anything that wasn't available when the car rolled off the assembly line so looking stock is a real advantage over here.
I think the Grand Prix radio is a good solution. Just be careful if you get a used unit & make sure it plays or can be returned.
(BTW, capacitors can be replaced even in Australia.)
[This message has been edited by Mike in Sydney (edited 08-06-2023).]
Mike in Sydney
Report this Post08-05-2023 07:13 PM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mike in Sydney
Member since Sep 2011
double post
[This message has been edited by Mike in Sydney (edited 08-05-2023).]
fierosound
Total ratings: 286
Report this Post08-06-2023 10:43 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe you can post the information here for those who need a repair.
Vintage-Nut
Report this Post08-06-2023 11:28 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
BTW, aluminum electrolytic capacitors are the 'weak link', and they'll gradually lose capacitance which the ‘typical’ life expectancy is about 20 years.
By replacing them and members who can solder, capacitors are cheap and buy 'Audio' capacitors.
Total ratings: 463
Report this Post08-07-2023 08:54 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well... obviously I had a brain cramp, and posted the cassette version. The next post, after yours, shows the CD version.
Total ratings: 463
Report this Post08-07-2023 09:06 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Oct 1999
Several people have recommended the Newport radios, like the ones that Crutchfield sells.
I have one of those, and while it seems to work decently, including the Bluetooth functionality, it's complicated.
Also, when you choose the amber lighting (you have a choice of amber or blue, switchable) the clock/frequency display is quite dim, and washes out in sunlight. This, in a "no sunroof" car.
The display also doesn't dim with the headlights being turned on, IIRC. Again, it's manually switchable, in the menus.
[This message has been edited by Raydar (edited 08-07-2023).]
fierosound
Total ratings: 286
Report this Post08-07-2023 12:05 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
PDF manual for Newport radio for those who want to browse the features.
https://help.retromanufactu...wledge-base/newport/
[This message has been edited by fierosound (edited 08-07-2023).]
rebeck02
Report this Post08-07-2023 12:09 PM Click Here to See the Profile for rebeck02Send a Private Message to rebeck02Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hello All, I appreciate everyone's feedback and insights. You have all been a big help and given me plenty of options. Time to seek and find. reb (Roger)
css9450
Total ratings: 86
Report this Post08-07-2023 12:43 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm pretty sure it was these people: https://mandrautoelectronics.com/ It's been more than a decade since I used them and they've upgraded their website from it's earlier "Internet 1.0" appearance. But my headunit has been perfect ever since. Radio, cassette, etc. all good.
Mickey_Moose
Total ratings: 144
Report this Post08-17-2023 05:16 PM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
None of what is mentioned is a problem if the unit is properly "restored/rebuilt". Caps are replaced (proper audio caps), lasers are cleaned and calibrated, belts replaced (if any), lamps replaced, mechanisms clean/aligned/lubricated - there are several people that rebuild vintage radios back to new condition. They usually specialize in a specific type/brand, so you will have to do some digging on who does what.
Yes, if you buy one from a scrap yard - it may not last, but if properly rebuilt they can last another 10+ years.
I have rebuilt my vintage period correct Alpine deck and expect it to last another 30 years, even added full Bluetooth to it as well so I get the modern conveniences of hands free calling and music playback.
[This message has been edited by Mickey_Moose (edited 08-17-2023).]
richard in nc
Report this Post08-19-2023 08:16 AM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
its insane that with all the gm and chrysler cars made with 1.5 din radios that theres no [good?] aftermarket radios available.i have a 1.5 Pioneer DEH-P77DH radio with aux input,satilite radio and cd i may install.i bought it for a 1984 camaro,transfered it to a 1989 camaro which got totalled,transfered it to a ford areostar which blew a head gasket and currently have it in a 1996 dodge caravan.
Total ratings: 463
Report this Post08-19-2023 10:07 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check out the tuner in your DEH-P77DH carefully. Mine always sounded like it was "off frequency" just a bit. Never got it sorted.
I even had the service manuals for it. Couldn't find any way to adjust it. (I worked on commercial 2-way FM radio for a living. I know how to align receivers. Should have been about 1/4 turn on a coil core. But not this one.)
OTOH, I don't know of anyone else who ever had a problem with a Pioneer tuner. I probably just got a "lemon".
Sorry... don't mean to "whiz all over" peoples' comments. Just my own experiences.
Vintage-Nut
Report this Post08-19-2023 11:11 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
This link from Michigan Fiero Club is a tip for the GM auto reverse AM/FM tape player....
https://www.michiganfierocl...965d57bc7ae3c7b5.pdf
richard in nc
Report this Post08-19-2023 06:07 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
i only listen to am or fm when i have to so i haven't noticed.
