  How to disable TCC lock-up solenoid
How to disable TCC lock-up solenoid by Nasta
Started on: 06-27-2023 09:51 PM
Replies: 10 (264 views)
Last post by: jelly2m8 on 06-29-2023 02:00 AM
Nasta
Report this Post06-27-2023 09:51 PM Click Here to See the Profile for NastaSend a Private Message to NastaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Car is down and the part is a couple weeks away, what and how can I bypass this and will there be any issues driving at highway speeds to and from work? Pictures and/or layman's term would help, I'm not very car-savvy.
jelly2m8
Total ratings: 242
Report this Post06-27-2023 10:27 PM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Let it cool off and unplug it, if I recall it's a blue connector down on the front / left side of the case
[This message has been edited by jelly2m8 (edited 06-27-2023).]
Report this Post06-27-2023 10:29 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just unplug the trans and make sure the plug and wire can't move and hit the exhaust etc.
Blue plug on Front of unit should see from above.
Downsides:
The Trans will get hotter because no TC locking.
Will eat more Fuel and engine rev's 200-300RPM higher all the time.
Many hate TC before TCC feature became standard will hate more because TC design change to more torque boost expect to lock at higher speeds that eliminate TC function.
OldGuyinaGT
Report this Post06-27-2023 10:39 PM Click Here to See the Profile for OldGuyinaGTSend a Private Message to OldGuyinaGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
IMO the easiest way to disable the TCC is to disconnect the TCC switch on the brake pedal. It's located above the brake light switch. I can't easily get to the TCC connector on the transmission from above.
Nasta
Report this Post06-27-2023 11:42 PM Click Here to See the Profile for NastaSend a Private Message to NastaEdit/Delete MessageReply w/QuoteDirect Link to This Post
In the front or the back? I appreciate the replies but I just don't get unplugging the trans, what case has a blue connector or the front of what unit means. Will I need to take the rear driver's side wheel off and access the panel behind it or can I just pop a bonnet and reach in?
jelly2m8
Total ratings: 242
Report this Post06-28-2023 01:17 AM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Should be able to do it from the top looking down the front of the transaxle
With the drivers side rear wheel off and the rubber splash shield ( if that still exists) you should be able to look in at the front of the transaxle and see a connector plugged in pointing to the front of the car. It's a square 4 wire blue connector, the only one plugged into the transaxle in there. The connector at the top rear is your Range switch, do not unplug this.
[This message has been edited by jelly2m8 (edited 06-28-2023).]
Report this Post06-28-2023 06:46 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is a picture of it unplugged.
Nasta
Report this Post06-28-2023 11:04 PM Click Here to See the Profile for NastaSend a Private Message to NastaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you so much! I can work with this.
Report this Post06-29-2023 12:01 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm surprised that no one has seemed to take any notice of/interest in this suggestion. Would it not do the trick?
OldGuyinaGT
Report this Post06-29-2023 12:52 AM Click Here to See the Profile for OldGuyinaGTSend a Private Message to OldGuyinaGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I know for certain it will properly disable the TCC because my TCC was not operation and just this last weekend I traced the problem to this switch (by the way, if you're clever you can rebuild this switch. I also discovered that last weekend). Besides, the wiring schematics show it to be a series element.
I just thought it was a faster/easier way to disable the TCC because you don't have to do anything else but reach under the dash and unplug it. To each his own, I guess.
jelly2m8
Total ratings: 242
Report this Post06-29-2023 02:00 AM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
At my age, it's just easier to reach down and unplug the trans LOL, even if I was still limber enough it's just faster to unplug the trans
[This message has been edited by jelly2m8 (edited 06-29-2023).]
