  LZ9 VVT / VCT, vs retrofit earlier "performance" cam.
LZ9 VVT / VCT, vs retrofit earlier "performance" cam. by Raydar
Started on: 06-27-2023 07:28 PM
Replies: 13 (540 views)
Last post by: Raydar on 07-21-2023 07:34 PM
Total ratings: 461
Report this Post06-27-2023 07:28 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can almost see the eyes rolling, but in all my years, here, I have never seen anyone make this comparison.
Assuming that I can use the stock PCM to accommodate the VVT*, or an earlier PCM since/if the VVT will no longer be an issue (I'm not afraid of either one.)
Obviously (unless I've had my head in a dark place) there are no performance cams available for the VVT engines.
There are plenty of performance cams available for the earlier engines. The retrofit to the LZ9 requires inserts to tighten up the cam clearance for the cam journals. Those inserts are also readily available.
The one notable exception is the LNJ 3400 ('08 Equinox) that also uses a fixed, large journal cam. Obviously, it's not a performance piece. Guessing it can be reground, but it seems like a waste of effort.
The question is, which method will provide the best performance, with a manual trans?
I liked the way my Crane 272 sounded in my 3.4, and it pulled like a train on the top end, but I also have a VVT 3.5 in my G6, and GM did such a good job with it that it seems a shame to mess with the VVT, even if it doesn't have the slightly lumpy idle.
I'm not averse to doing a bit of porting to the intakes, and changing throttle bodies. I don't really want to do a bunch of head work, though, other than really basic stuff. The engine will remain N/A.
Will those mods help the performance of the VVT motor as much as they will the "fixed cam" motor option? Can the VVT cam use all that air flow?
Thanks.
*And yes I know that "VCT" is actually what's happening, but "VVT" gets used a lot more frequently.
Total ratings: 461
Report this Post07-01-2023 05:00 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
<crickets>
A_Lonely_Potato
Report this Post07-01-2023 09:31 PM Click Here to See the Profile for A_Lonely_PotatoSend a Private Message to A_Lonely_PotatoEdit/Delete MessageReply w/QuoteDirect Link to This Post
way above my pay grade, sorry lol
Total ratings: 461
Report this Post07-01-2023 10:11 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you sir!
I just figured there was someone here who had built out an N/A LZ9, with deleted VVT, and maybe could give me an an idea what to expect.
Total ratings: 260
Report this Post07-02-2023 08:11 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would keep the VVT but it would take a fair amount of research work and tuning to maximize its performance. But once done, it would likely have a wider power band, better fuel economy, and fewer compromises than the single fixed cam setup. You could even make it chop at idle with some timing parameter changes in the tune. I would start with a custom cam with 10-15 degrees more duration and lift that allows use of peak head flow and then focus on the range limits and VVT adjustments to the cam to maximize idle, cruise, and WOT power up to 7000 rpm.
If all you want is a peak power, then you can install a fixed camshaft designed to reach that goal, but idle, fuel economy, and low rpm torque/drivability will suffer.
A_Lonely_Potato
Report this Post07-02-2023 01:13 PM Click Here to See the Profile for A_Lonely_PotatoSend a Private Message to A_Lonely_PotatoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Raydar:
Thank you sir!
i may be wrong, but it just doesn't seem to me like there are that many LZ9 builds. its the engine i'm wanting to do when i get around to swapping, and there doesn't seem to be all that much information specific to them on this forum. i would think it would be a popular swap, close to the same output as the 3800SC, but on reg gas and N/A. sure its got its techy stuff like the VVT and variable intake, but those can be deleted without *too* much work.
everything i've seen suggests its a pretty strong engine. there was a guy(slowv8fiero) who boosted his to 600hp on stock bottom end, so i would think ~350hp would be pretty achievable.
Total ratings: 461
Report this Post07-02-2023 04:17 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks again, gentlemen.
600 HP on a stock bottom end. Maybe.
He's done some nice stuff, and knows his way around most any 60 degree V6. Doesn't mind breaking stuff to find out what works.
Although he makes that 600 claim, I've yet to see a dyno sheet. Although, to be fair, I haven't looked really hard. (He's the one that used to troll V8 owners about posting a dyno sheet or time slip. Yeah... that guy. Irony. )
pmbrunelle
Total ratings: 63
Report this Post07-02-2023 06:14 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
522 whp on dynojet with graph:
https://www.realfierotech.c...iewtopic.php?t=21900
I think that 600 hp is what Shaun estimates at the flywheel based on the wheel horsepower measurement.
That's with a junkyard LZ9 engine and LNJ camshaft.
A_Lonely_Potato
Report this Post07-02-2023 10:50 PM Click Here to See the Profile for A_Lonely_PotatoSend a Private Message to A_Lonely_PotatoEdit/Delete MessageReply w/QuoteDirect Link to This Post
yeah i knew it wasn't that exact, and i did forget to mention it was his claim to be a stock bottom end. he did wind up blowing it up im pretty sure though haha
Total ratings: 461
Report this Post07-03-2023 10:09 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well... okay. Fair enough. I stand corrected. Thanks!
I never saw that. I guess I figured that if they weren't posted on one of his YouTube vids, they didn't exist.
But he's running a stock cam, since he's boosted to a fare-thee-well. I'm not interested in boosting. At least not at this point.
But at least it proves the sturdiness of the LZ9 bottom end.
La fiera
Report this Post07-13-2023 11:09 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://youtu.be/vdTY9J9crQw
These boys from Canada did a good job on showing what an NA 3900 can do. I think they use the LNJ cam also.
ericjon262
Total ratings: 67
Report this Post07-17-2023 12:54 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
there is a 3rd option that you don't appear to have explored yet, and that would be having a stock cam reground. Material can be removed from the bas circle of the cam, to increase lift and duration to some degree. I think this could be a compromise between the options you are exploring, not quire the all out performance of a dedicated performance cam, but also not removing VCT. you will NEED to check piston to valve clearance as well. I think you're somewhat local to me, and therefore possibly somewhat local to Powell Machine, who does offer cam grinding, it may be worth a phonecall.
https://www.powellmachineinc.com/
I've been extremely interested in making a performance VCT cam for a LZ engine, it could be alot of fun!
ericjon262
Total ratings: 67
Report this Post07-17-2023 12:56 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Member since Jan 2010
they used a stock LNJ cam, they also had a few cooling system issues that weren't very well sorted, for some time, their thermostat didn't have a bypass, so water wouldn't have been flowing through the block, they ended up removing the thermostat for at least a couple of their races, I'm not sure what they have done since then, I'm fairly certain their truck wasn't ready for the start of their race season this go around.
Total ratings: 461
Report this Post07-21-2023 07:34 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
It did cross my mind (and Guru also suggested it), but I didn't know of anyone who even might be able to do it. Now I do. Thanks for that! (I messaged a sort-of local shop who does lots of fancy sh!t with LS motors, and asked about 3900 stuff. Head porting and such. Never even bothered to reply. Figured that nobody wanted to touch it.)
I am in west-middle GA. I can almost throw a rock and hit Ranburne AL. But yeah... Powell's is definitely do-able. Not exactly local, but at least they're not in Indiana or something.
I really don't mind the VVT. I really like how the LZE (3.5) in my G6 runs, but more power is just about always better.
Thanks again! And thanks for the vid, LaFiera. I'll check it out.
[This message has been edited by Raydar (edited 07-21-2023).]
