  84 Duke Auto to Manual Swap EPROM Concern
84 Duke Auto to Manual Swap EPROM Concern by Derekw66
Started on: 05-22-2023 12:09 PM
Replies: 27 (363 views)
Last post by: Derekw66 on 08-03-2023 05:00 PM
Derekw66
Report this Post05-22-2023 12:09 PM Click Here to See the Profile for Derekw66Send a Private Message to Derekw66Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey guys, I'm still having idle and throttle response issues and I am still running the auto trans computer since my donor manual computer won't even start the car. What can I do to reflash the eprom to a manual (specifically, like where to get the program and what sort of software and cable) or should I just find another computer? Thank in advance.
Report this Post05-23-2023 09:59 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Derek, I don't think the ECM is really your problem (though that ECM might just be dead). I think there should be some other issue related to your idle / throttle response issues. Do you have a link to where you posted the issues you're having? I can't remember seeing it. Otherwise, can you post them in here?
FYI, I MAY have a spare 84 / 4-Speed ECM and chip. I was just at my storage unit a couple of weeks ago, and had a stack of ECMs that I'd apparently collected. I wrote what each of them were for on the front, so if you have no other options, then I'll look and see if I have one and you can have it for the cost of shipping.
Derekw66
Report this Post05-23-2023 04:40 PM Click Here to See the Profile for Derekw66Send a Private Message to Derekw66Edit/Delete MessageReply w/QuoteDirect Link to This Post
82 T/A I would love to have a 4 speed ecm. I'm not sure why the 86 ecm from my donor car wouldn't even fire the engine but I know 84 was a special year for a lot of little differences from all of the other years. Let me know how you want me to pay for shipping an i'll gladly take it off your hands. I''ve done a full engine rebuild going .030 over bore with aluminum pistons as well as a lightened cam gear. I'm still running the original injector but have a new TPS and AIC valve set to the correct depth. I've reset said IAC as per the book and driven it several miles above the 40 or 45mph threshold. Timing has been set and reset and it still wants to hunt for idle from 300-1500 as well as bucking under acceleration. Any attempt at acceleration from idle to 3k is a struggle. Also, no vacuum leaks detected. I'd like to cross the ecm off of potential culprits. It's my sons car and he's anxious to drive it since he's back from college, can't blame him, I've dragged my feet on this thing for nearly 18 months. lol
Report this Post05-23-2023 05:22 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Easiest thing (because I'm lazy) is you send me an empty box with a shipping label on it! Haha... only problem is, that it's in the storage unit, which is a good 4 hours away. I likely won't be back to the storage unit for a couple of weeks. But I'll double check to make sure I don't have it at home. If I indeed have it, it's yours.
Derekw66
Report this Post05-23-2023 05:39 PM Click Here to See the Profile for Derekw66Send a Private Message to Derekw66Edit/Delete MessageReply w/QuoteDirect Link to This Post
I get it, I enjoy doing nothing when it's "at all possible!) if you like, PM me your address and I'll get you a box.
Derekw66
Report this Post06-14-2023 04:55 PM Click Here to See the Profile for Derekw66Send a Private Message to Derekw66Edit/Delete MessageReply w/QuoteDirect Link to This Post
Any chance you have the ECM laying around yet?
Report this Post06-14-2023 06:21 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm hoping to go up this weekend (Sunday) and I'll let you know. Everything is in my storage unit.
Derekw66
Report this Post07-11-2023 09:03 AM Click Here to See the Profile for Derekw66Send a Private Message to Derekw66Edit/Delete MessageReply w/QuoteDirect Link to This Post
Any chance you made it up to your storage unit yet?
Total ratings: 328
Report this Post07-11-2023 10:46 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Fiero ECM's run almost the identical program, except that the auto version provides a signal for the TC lock up and the manual version provides a signal for the shift light. This is as close to plug and play as you can get. The software can be changed in the eprom (chip) but the change wont effect engine operation. As for your problem; it could be the ECM (they can go bad) or a number of other issues, most common would be spark or a vacuum leak. Have you checked for spark and/or a vacuum leak? Could be other things like a clogged fuel filter, low fuel pressure or dirty injector. You will need to do the checks to find the problem but I would focus on spark first.
Derekw66
Report this Post07-11-2023 08:13 PM Click Here to See the Profile for Derekw66Send a Private Message to Derekw66Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, I’ve done all of the things I can think of except for turning the dreaded screw on the side of the throttle body. The engine was fully rebuilt with a .030 bore and aluminum pistons, new vacuum hoses of course, new injector and timing checked and rechecked. Even before the engine rebuild and auto/manual swap, it idled like crap. It has gotten worse though. Aside from sourcing a slightly richer injector from another vehicle, I’m out of options. I’ve also done the IAC valve procedure a few times knowing 84 is alone in many of the seemingly interchangeable parts. Getting a known good ecm from a manual seems like a logical next step to get this thing idling normal. It’s basically undriveable at this point with it’s bucking and slow to no throttle response until I get the revs up to 3k or so. TPS is only about a year old so I have no reason to think this is bad although I may have to revisit it if something doesn’t give up it’s secret soon.
buddycraigg
Total ratings: 478
Report this Post07-11-2023 10:23 PM Click Here to See the Profile for buddycraiggSend a Private Message to buddycraiggEdit/Delete MessageReply w/QuoteDirect Link to This Post
let's rule somethings out.
IACV has nothing to do with the system after you start stepping on the gas pedal. so that's out.
Idle stop screw doesn't have anything to do with it after you step on the pedal. so that's out.
Take the top of the air filter off and watch the spray coming from the injector.
it should look like the water coming from your shower in the bathroom. Even at idle.
The throttle body has a pressure regulator built into them.
That is what I would check next.
Derekw66
Report this Post07-13-2023 07:35 AM Click Here to See the Profile for Derekw66Send a Private Message to Derekw66Edit/Delete MessageReply w/QuoteDirect Link to This Post
The injector has a nice triangle shaped mist spray pattern, no concerns there.
buddycraigg
Total ratings: 478
Report this Post07-13-2023 07:33 PM Click Here to See the Profile for buddycraiggSend a Private Message to buddycraiggEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm out of ideas.
Total ratings: 465
Report this Post07-13-2023 07:46 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm not sure what you think messing with the idle stop screw might accomplish... besides screwing things up even more.
What is the actual fuel pressure?
What is the ignition timing set to?
Did you have the ALDL jumper in place when you set it?
Are the distributor cap and rotor in good shape?
Have you checked the resistance of the spark plug leads?
Have you triple-checked that the spark plug leads are attached to the correct plugs?
Will the spark jump a full 1/4" gap outside of the combustion chamber? (And no, testing with a 0.060" gap means nothing.)
[This message has been edited by Patrick (edited 07-13-2023).]
Derekw66
Report this Post07-13-2023 08:34 PM Click Here to See the Profile for Derekw66Send a Private Message to Derekw66Edit/Delete MessageReply w/QuoteDirect Link to This Post
I don’t think it will help at all, alas, not touched even though it seems like it should to most.
That’s something I need to do over, I was getting 30-35 when cranking but it never fired up, wasn’t my tester and it needed to go back, so that is a maybe, but fuel pump and filter are new.
8 degrees btdc
Yes
New
Swapped all of them over with the donor car, no change
Yes but I will again
I haven’t tried that, I’ll put it on my list
Total ratings: 465
Report this Post07-13-2023 09:03 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
That’s something I need to do over, I was getting 30-35 when cranking but it never fired up...
Considering that the factory specs for the 2.5 duke are 9-13 psi, something's screwy here.
What fuel pump do you have installed? Sounds like you've got one for the 2.8 engine.
buddycraigg
Total ratings: 478
Report this Post07-13-2023 10:24 PM Click Here to See the Profile for buddycraiggSend a Private Message to buddycraiggEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was thinking more like 14 too.
Derekw66
Report this Post07-14-2023 08:22 AM Click Here to See the Profile for Derekw66Send a Private Message to Derekw66Edit/Delete MessageReply w/QuoteDirect Link to This Post
I’ll get another tester and confirm whats true, but I sill believe the manual ecm would have different idle parameters and throttle response logic, I’ve read in nearly all auto-to-manual swaps the ecm needed to be replaced as well.
Report this Post07-14-2023 01:30 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, Duke gets 9-13PSI fuel pressure.
But Note that many Test gauge w/ 80 to 100+PSI gauges are not every accurate showing that numbers. 14 maybe ok but definitely not ~ 20 or more even with high range gauge.
Most standard gauges aren't very accurate at highest and lowest numbers of whatever numbers on the scale.
Is why I found large diameter 0-30PSI gauge and install that in the test set.
Plus needs TBI test Adapter.
https://www.fiero.nl/forum/Forum2/HTML/146121.html
High Pressure can cause ECM setting code 45 and can be several things...
Iffy regulator
pinch return line
crap blocking return line
can kill the pump at high pressure too because often reduce fuel flow means can cool or lube right like that, Worse if tank is near empty because no external gas to help cooling.
Derekw66
Report this Post07-15-2023 07:36 AM Click Here to See the Profile for Derekw66Send a Private Message to Derekw66Edit/Delete MessageReply w/QuoteDirect Link to This Post
So no one thinks an automatic ECM being in a now manual car can cause this issue? Just trying to rule this out as a possibility.
buddycraigg
Total ratings: 478
Report this Post07-15-2023 05:06 PM Click Here to See the Profile for buddycraiggSend a Private Message to buddycraiggEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't
Total ratings: 465
Report this Post07-15-2023 05:28 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
When the fuel pressure appears to be 3x more than it's supposed to be, I think that should be the #1 priority to deal with.
Total ratings: 328
Report this Post07-22-2023 09:57 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like the wrong pump is installed. .
Derekw66
Report this Post07-28-2023 07:33 PM Click Here to See the Profile for Derekw66Send a Private Message to Derekw66Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, I triple checked the timing and it is spot on 8 degrees, idle is better but throttle response is a bit sluggish with no load but ok. It wants to die when I get the clutch about half out, begins to shutter and shake the whole car. I give it a bunch of throttle but it struggles to move. with the clutch fully engaged it begins to buck and throttle response is nearly nil. It's either wanting to die or needs 4k rpm. Fuel pressure is rechecked with a known good gauge this time and is solid at 12psi with key on, at idle and under no load revving. TPS was rechecked to make sure it is connected properly, no vacuum leaks. I'm basically out of ideas other than a manual cpu installed since this is a auto/manual swap and I still have the auto's computer installed.
Total ratings: 207
Report this Post07-28-2023 07:59 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Derek,
Back to your ECU/EPROM...
All 1984 cars used the 1226156 ECU
The manual trans cars used these EPROMS
M19 4 speed (4.10 final)
DDVB0203
DDB3044
AMPM9338
MY8 (3.32 final)
DDC0196
DJC1438
AMPM9342
Hope this helps
Total ratings: 465
Report this Post07-28-2023 07:59 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
At an RPM that allows the engine to run at a relatively constant speed, I'd ground out (not disconnect) one spark plug lead at a time to ensure that each cylinder is playing an equal role in powering the engine. The RPM drop should be similar across the board.
Derekw66
Report this Post07-29-2023 08:25 AM Click Here to See the Profile for Derekw66Send a Private Message to Derekw66Edit/Delete MessageReply w/QuoteDirect Link to This Post
Engine runs smooth with no load applied, I checked exhaust manifold temps and they were all between 305-335.
Derekw66
Report this Post08-03-2023 05:00 PM Click Here to See the Profile for Derekw66Send a Private Message to Derekw66Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well great news, the car is running as it should, I honestly don't know what I did to get it sorted. After I connected the fuel pressure gauge it started running better with better throttle response. I took off the gauge and it still ran better as far as throttle response. I drove it without the air cleaner connected and it ran great but I had a check engine light for the map sensor. I put the air filter back on, checked the connections at the map sensor and after driving for a few miles the light went out. It comes on sometimes when reversing but goes off again shortly after. I'm lost but somewhat content for now.
