  Paint for 88 GT
Paint for 88 GT by Duck 1
Started on: 05-22-2023 09:59 AM
Replies: 12 (286 views)
Last post by: olejoedad on 06-02-2023 12:39 PM
Duck 1
Report this Post05-22-2023 09:59 AM Click Here to See the Profile for Duck 1Send a Private Message to Duck 1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am ready to paint my 88 GT "T" top but need to know the proper paint to use on the plastic body. Since these body's were not fiberglass is there a particular type pain or primer to use on them. I am going back to the original white color.. Has anyone ever tried rattle can painting on these cars, if so, what type ? Thanks in advance for any help.
Dukesterpro
Report this Post05-22-2023 02:52 PM Click Here to See the Profile for DukesterproSend a Private Message to DukesterproEdit/Delete MessageReply w/QuoteDirect Link to This Post
No info for you, but I have been bouncing the idea of rattle paint for a while. Proper priming and sanding put it on thick then buff it down. Might look real good!
Duck 1
Report this Post05-22-2023 03:29 PM Click Here to See the Profile for Duck 1Send a Private Message to Duck 1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I guess the only way to find out is to try !
Dukesterpro
Report this Post05-22-2023 04:31 PM Click Here to See the Profile for DukesterproSend a Private Message to DukesterproEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll risk it with you. I'll pick up some cans tonight
Total ratings: 207
Report this Post05-22-2023 04:43 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tractor paint in cans is much better than the regular paint.
Dukesterpro
Report this Post05-23-2023 08:14 AM Click Here to See the Profile for DukesterproSend a Private Message to DukesterproEdit/Delete MessageReply w/QuoteDirect Link to This Post
BEHOLD! THE FARMALL RED FIERO.
actually that would be funny as hell.
Duck 1
Report this Post05-23-2023 08:53 AM Click Here to See the Profile for Duck 1Send a Private Message to Duck 1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I used tractor paint before on another project but I can't remember if it had much gloss.
Total ratings: 207
Report this Post05-23-2023 09:03 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tractor paint has more pigment and solids in it, and is very durable.
Wet sanding and polishing will bring up the gloss.
A friend uses it on a lot of projects, it looks good for a rattlecan option.
css9450
Total ratings: 87
Report this Post05-23-2023 09:08 AM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
Years ago, someone here on the forum did exactly that. They even applied it with a roller! But they went to great lengths to apply it smoothly and wet-sand and buff each coat and the end result was quite good.
Duck 1
Report this Post05-23-2023 12:53 PM Click Here to See the Profile for Duck 1Send a Private Message to Duck 1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Good information.
Total ratings: 207
Report this Post05-23-2023 01:09 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
A note of caution.....
Even the best job with tractor or other rattlecan paint will not look as good, or hold up as long as properly applied automotive paint.
Go cheap now, and expect to do it again.
Firefox
Total ratings: 240
Report this Post06-02-2023 10:55 AM Click Here to See the Profile for FirefoxSend a Private Message to FirefoxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good morning....
You can use regular automotive paint and primer. The newer bumper covers on vehicles are just as flexible as ours are and the newer paints are inherently flexible, unlike the enamels and lacquers of old that needed a flex additive. Prep is the key to any paint job but I prep a Fiero just like I prep any metal vehicle surface. Clean, smooth and sanded evenly.
I'm not a fan of the spray bomb as these paints are usually not flexible enough and won't last on our cars. That and it's very difficult to get a nice finish that won't look like a rattle can spray job. The spray nozzles on cans tend to clog during use and really mess up a spray pattern and it's difficult to fix that and make it look good. Paint splatter sticks out. If you ever decide to repaint or even just repair a rattle finish you might have to strip the entire panel or panels to start over. Rattle cans are usually enamel of some sort and the finish isn't easily repaired. If you ever decide to repaint the entire car you'll have to strip off the entire rattle finish as real auto paint doesn't like rattle finishes. Just a thought.
Good luck.
Mark the paint guy
Total ratings: 207
Report this Post06-02-2023 12:39 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great advice in the previous posting.
