  Rear brake pad retainer
Rear brake pad retainer by bonaduce
Started on: 05-21-2023 04:46 PM
Replies: 4 (418 views)
Last post by: theogre on 05-22-2023 10:36 PM
bonaduce
Report this Post05-21-2023 04:46 PM Click Here to See the Profile for bonaduceSend a Private Message to bonaduceEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's been a few years since I did rear brakes but I do not remember it being impossible to get the inner pad retainer over the piston. My grooves don't line up as they should with the clips. Any secrets you wise gents
Dan
Report this Post05-22-2023 01:04 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is/Was 2 "clips..."
Wire type for Old Style Pistons w/o 4 notches. Wire just snaps on.
Stamped SS for New Style Pistons w/ 4 notches to attach them. Clip ears goes in the notches then turn 90°.
tbone42
Total ratings: 128
Report this Post05-22-2023 03:49 AM Click Here to See the Profile for tbone42Send a Private Message to tbone42Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey man
I *just* did these this week. I had to bend the tabs on the clip just slightly and it snapped on. Same with where it connects to the pad ..it's like all the new clips come set up for a different caliper piston. Just go a little at a time until it finally snaps on, make sure the boot isn't interfering with the fit. If you are reusing old calipers, maybe clean the top of the piston with a wire brush to make sure there's no crud keeping the retainer clip from attaching. (Careful not to tear the boot)
Finally, I just ran the last 25k miles without the clips after my last brake job so if you can't get it to go on, just hold the inboard pad in place as you install the caliper on the rotor. It works, pad never flew out of there or anything.
bonaduce
Report this Post05-22-2023 07:55 PM Click Here to See the Profile for bonaduceSend a Private Message to bonaduceEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks gents. The piston on the left rear looked funky and only had one spot to put clips in and rotate it. Right side piston looked right and no issue with that retainer. Thanks again
Dan
Report this Post05-22-2023 10:36 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
The clips hold inner pad so:
Won't drag and wear fast or cause brake heat.
Won't rattle and wear the bracket or make noise can hear by driver or others.
