  "Volts" rally gauge warning light
"Volts" rally gauge warning light by Time Traveller
Started on: 05-21-2023 02:56 PM
Replies: 4 (257 views)
Last post by: ArthurPeale on 05-23-2023 03:32 PM
Time Traveller
Report this Post05-21-2023 02:56 PM Click Here to See the Profile for Time TravellerClick Here to visit Time Traveller's HomePageSend a Private Message to Time TravellerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Recently, my "volts" light has been on (but like, half on, 25% on, barely on, and often off), but the system voltage seems normal (12.5v off, 14.5v engine running, accessories off), the battery is new-ish, and the gauge itself shows voltages in the normal range for the current duty cycle (off/running, AC on/off, etc). I did recently have the rally pod off to glue down the vinyl, but the connector pins are clean, and upon inspection, it looks like the logic switch that controls the warning light isn't in the pod anyway, and the light just connects directly to the two rightmost pins when looking at the back of the gauge pod's PCB.
Where does the warning light's logic happen? Is this a sign of some problem unrelated to out-of-range system voltage? Is there some ground that needs cleaning, that I haven't already?
Report this Post05-21-2023 04:58 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The CHARGE lamp is connected to the GAGE fuse on one end, and the small plug on the ALTERNATOR (pin L).
The CHARGE lamp will only illuminate when there is a low voltage situation across the light.
At KEY ON the GAGE fuse has power, but pin L on the ALTERNATOR acts as a ground. The CHARGE light is illuminated.
When the ALTERNATOR begins to produce voltage, the CHARGE lamp goes out because pin L now has an electrical charge.
The CHARGE light is part of a voltage balanced circuit - when the circuit becomes unbalanced, the light will glow to varying degrees.
You might want to have your alternator tested......
Report this Post05-22-2023 01:11 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
turn key On, do not start. Should have a light in the dash or pod should be On.
If not then bulb, wiring or the Alt has problems.
Time Traveller
Report this Post05-22-2023 10:29 PM Click Here to See the Profile for Time TravellerClick Here to visit Time Traveller's HomePageSend a Private Message to Time TravellerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Volts light is on with car off. I guess the intermittency of the light being on with the engine running is what threw me for a loop, as well as the normal voltage throughout the run cycle. I'll bring it somewhere to have it properly tested.
ArthurPeale
Report this Post05-23-2023 03:32 PM Click Here to See the Profile for ArthurPealeSend a Private Message to ArthurPealeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had a similar issue. Turns out the tension bolt had backed off, and it wasn't charging well.
Got Dodgerunner's tensioner bracket, installed a tensioner, and fixed that issue.
