  BARO sensor location
BARO sensor location by TurboGN
Started on: 05-10-2023 02:04 PM
Replies: 4 (384 views)
Last post by: TurboGN on 05-11-2023 05:58 PM
TurboGN
Report this Post05-10-2023 02:04 PM Click Here to See the Profile for TurboGNSend a Private Message to TurboGNEdit/Delete MessageReply w/QuoteDirect Link to This Post
Anyone know where the BARO sensor might be located on a L32 swapped Fiero GT?
All the information I can find for the 2007 Grand Prix it came out of says it should be right next to the MAP sensor open to the air with no vacuum line. It's not there and I have search around and can't find one.
Report this Post05-10-2023 03:10 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not sure of that engine...
But Baro is Often the MAP...
ECM/PCM just read MAP before engine starts then use that value as you drive.
Unless the altitude charges a lot w/o turning off, most vehicles are happy with startup baro value.
Most people stop and shut down for gas food etc before baro value might matter.
Note: GM has 3 of "old" MAP sensors. All look same but have different plug. Famous Green plug uses 1 Bar sensor. Turbo/super charge engines have 2 or 3 Bar sensors. The plug body and socket are "keyed" for whichever type.
If have a ECM scanner...
Scan engine w/o starting to read Baro value.
Turn off the key.
Put a tiny bit of vacuum on MAP tube and hold it.
Turn key on to the scan ECM again. Baro value should change.
TurboGN
Report this Post05-10-2023 06:10 PM Click Here to See the Profile for TurboGNSend a Private Message to TurboGNEdit/Delete MessageReply w/QuoteDirect Link to This Post
Turn off the key.
I tried it and it does change both readings which is strange because from the factory they had seperate sensors.
Thanks for the help.
Report this Post05-11-2023 08:20 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Many "books" are wrong to start or for other years.
Worse for 3rd parties like Haynes example doesn't have any info for DIS or 700 series TBI in 87-88 Duke Fiero.
Even Fiero 84-86 had wrong rear brakes section in FSM copy/past from another model line.
TurboGN
Report this Post05-11-2023 05:58 PM Click Here to See the Profile for TurboGNSend a Private Message to TurboGNEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, doesn't that make things fun.
[This message has been edited by TurboGN (edited 05-11-2023).]
