Thank you Ogre... couple of questions to your responses...
| quote | Originally posted by theogre:
coolant hoses: If the metal is rusted then remove that before clamping a hose. To prevent rust, use very thin coat of permatex brake grease. so thin you barely use any and wipe off most you feel.
Thank you for this. Is this more or less what you're talking about, or acceptable?
https://www.amazon.com/Perm...icant/dp/B0018PSASU/
I don't mind buying it because I can use it for when I do brake jobs.
Just want to confirm, this won't cause any damage to the rubber hoses I assume?
Any preference on the type of hose clamps? I have normal hose clamps that came with the car... I also have stainless steel ones that are the normal worm-screw kinds, and then there are these stainless steel ones from Harbor Freight. Any thoughts on this?
I don't mind spending the money... this will be for my daughter's car, so I want it done the right way... not the ghetto way I used to do things ~20 years ago when I was 19-20 and working on my Fiero in the parking lot of my apartment complex.
Inside t-stat tube when off the car, remove rust in there then use Self Tinning Flux and heat to melt that so metal has some protecting. STF is available in plumbing dept of HD etc. Can't really do this on the car. Higher heat needed is much harder to handle w/o problems like burn other parts or get way to hot and warp the tube.
Thanks, yeah... I intend to eventually rebuild the engine, but I'll be taking stuff like this off... water neck, etc... and sanding / painting the outside at least.
| quote | Originally posted by theogre: fuel lines: Clean whatever rust then nothing where rubber joints like to tank line assem. If off the car and dry of fuel, can use STF on that too. Fuel lines aren't SS
But Fuel Filter Is SS and cause dissimilar metal rot...
I probably should have mentioned. I'm going to be replacing the entire pickup, fuel pump, everything, including the hard lines, all with brand new stainless steel lines from the Fiero Store. So everything will be SS. So when you say the STF... that's just flux, there's no metal or anything in it... are you saying I need to use some solder, or I'm just using the flux and then heating it so it spreads? I assume for the threads, I can use the Permatex fuel line sealant (meant for threaded fuel lines)? I think years ago... I put some plumbers tape (haha)... but I was a kid and didn't know any better. It hasn't leaked... so there's that, haha. But that's my car... my daughter's car will have all new parts.
Hahah! Yes... it's funny you send this link. This is literally the post that I read a week or so ago, that made me decide to simply replace EVERYTHING in the fuel line. I'm literally replacing the entire pickup, fuel pump, using the submersible fuel line (saw that post too), replacing the hard lines, and then also replacing the fuel filter, cleaning and painting the bracket, and rebuilding the TBI unit and replacing the injector too.
